Old 03-17-2016, 08:55 PM   #1
Rari's Avatar
Propane extension line
I have a Solera and wanted to hook up to the house tank but cant figure out how. I see something below the tank but the fitting wont fit. I got the 12 foot cable from Camping World but am new to Motorhomes and clueless.
Rari is offline   Reply With Quote
Old 03-18-2016, 08:08 AM   #2
Old Enough to Know Better
gasman6674's Avatar
IF your home is LP Gas you would have to connect between the house regulator and the house. The quick disconnect on your rig is low pressure. I strongly recommend that you contact your LP supplier as they are ultimately responsible for your system even if you own the tank. You could also connect tank to tank before the high pressure regulators but again please contact your supplier so it done safely
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 03-18-2016, 08:16 AM   #3
Pickin' & Campin'
gasman, I 'think' the Op is referring to his permanently mounted LP tank on his Solera as the 'house tank.'
He simply wants to connect a hose to that tank which he purchased at Camping World but the fittings are different.
I'm sorry I can't be of any help. I do not know what the fitting or the hose connection he is referring to looks like? Possibly pictures would help?
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 03-18-2016, 09:29 AM   #4
Rari's Avatar
I figure I will stop by Camping World and have them show me. Should have done that to begin with. I love this forum. We are new to the RV world had have a lot to learn. Thankx , y'all
Old 03-24-2016, 01:38 PM   #5
Propane line extension
I had this same challenge: wanted to run my gas grill off the RV line, and have the gas hose be long enough to get me out from under the awning. I bought the longer gas line at CW & figured out the connections.
I've attached pics to show how I do it. The pics show
1) the RV's gas feed that I want to connect to "as it normally is"
2 the RV gas feed when prepared to accept nozzle from gas hose
3) the male nozzle on the gas hose that you'll attach to the gas feed
4) the gas hose attached
5) very important! the RV gas feed with the valve open for gas flow
then, working the grill end
6) the female connector end of the gas hose
7) the female connector attached
8) very important! the valve open so gas can get to the grill
Hope this helps!
Name:	RV stowed.jpg
ID:	102696   Click image for larger version
Name:	RV Ready.jpg
ID:	102697   Click image for larger version
Name:	RV attached.jpg
ID:	102698   Click image for larger version
Name:	RV connected.jpg
ID:	102699   Click image for larger version
Name:	Gas hose grill end.jpg
Name:	Grill attached.jpg
ID:	102701   Click image for larger version
Name:	Grill connected for gas.jpg
John& Sherry
2016 2401S, towing 2013 Mini Cooper
Colorado Front Range
the1murphman is offline   Reply With Quote
propane
