08-28-2013, 04:41 PM
Propane fire
On a trip from PA. to Gatlinburg Tennessee this month in our class a 373ds motorhome we stopped at a roadside rest stop. when we returned to the rv smoke and flames were coming out of the side of the rv at the fridge access panel.. after turning off the propane and putting the fire out we found the fitting was finger tight...this coach only has 1600 miles on it...
08-28-2013, 04:47 PM
WOW!
What did the insurance co. or Forest River have to say?
2011 Flagstaff 831 RLBSS
08-28-2013, 05:00 PM
Sorry to hear about your new MH! Everyone okay?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
08-28-2013, 05:12 PM
nothing from forest river....insurance co working on it...
08-28-2013, 05:15 PM
everyone okay...motorhome can be repaired....thanks
08-28-2013, 05:23 PM
That fitting is a fridge manufacturer issue. The assumption during install is that the connections inside the unit by the manufacturer are "good" and the only ones that need checking are the ones made during the install.
Maybe those assumptions need to be "re-thought."
When I buy a house appliance, I assume the wiring and plumbing connections inside are OK and I only need to worry about plugging it in or hooking it up. Taking it apart to meter the connections and leak check the fittings internal to the unit has never come up at my house.
Sounds like this one was a "Friday Unit" and QA missed the loose B nut.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
08-28-2013, 05:39 PM
this unit seems like a Friday unit...every trip has a new problem...
08-29-2013, 07:10 AM
Old Enough to Know Better
Once you get it repaired have your propane dealer pressure test the whole system. That way you will at least know that there is no more issues.
Good Luck with your Claim
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle.
2020 Keystone Cougar 364BHL ,Gone 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
08-29-2013, 07:25 AM
Always Learning
Yes, have it tested and while it may be a little late now- there are actual automatic fire suppression systems designed for RV refrigerators. Might be worthwhile to get one for peace of mind.
Heck, I'd love to see manufacturers adopt fire suppression systems more like homes have had to.
08-29-2013, 07:26 AM
What Fire Ex. did you use? Was it large enough to put out the Fire or was other Fire Ex. needed? Did you have to (Unlock) a door to gain access for the propane valve? Sorry to hear about your Fire. Youroo!!
08-29-2013, 07:55 AM
Sorry to hear this...glad everyone was safe and the fire was put out before it took hold. I don't know how many of you listen to Pod Cast's...there are a few out there that focus on camping and RV'ing. The RV Navigator had a few discussing the Fridge fires and the automatic extinguishers that were mentioned here. The cause of the fires seems to be different than a loose connection but equally as frightening and more than often a total loss event.
08-29-2013, 09:47 AM
Notice!
RV Cooling Unit . Com they sell (Auto SS-30 Halon Fire Ex.) Price 175.00$@ Place one by (Refer.-W/H-Stove-Furnace-Converter) Total 1000.00$ Youroo!!
08-30-2013, 09:50 AM
Anacortesians
When we had our old Dometic fridge replaced with a new one earlier this year, one of the checks the installer at the RV repair place did was a 24-hour leak test on the fridge's propane system.
As I understood it, the system had a pressure gauge installed at the propane inlet to the fridge. The system was pressurized from the propane tank and then the tank valve was closed. After 24 hours there was no change to the pressure in the fridge line.
Frank and Eileen
No longer RVers or FR owners
08-30-2013, 10:41 AM
I have something similar to this installed in our fridge area.
Earl
2013 Berkshire 390BH / 360hp
08-30-2013, 11:21 AM
As far as "would a leak check have found the loose fitting" the answer is most likely "no" because it is on the other side of the gas solenoid valve.
It will not leak unless the solenoid valve is open.
04-02-2014, 09:35 PM
Insurance company will pay claim and then go after FR and furnace manufacture, this is from an insurance agent for 28 yrs. no opinion just fact.
