Old 06-27-2009, 05:23 PM   #1
Chris and Sara
propane gas switch over valve
Guys, on my 09 TT I have a valve that sits between the LP gas tanks. It has an arrow that points to one tank or the other. After using what I thought to be a lot of propane, I took the tank to the fill station today. It only took 3 gallons. I thought with the switch in place, it would only pull gas from whatever tank the arrow was pointing to, am I missing something here?
2004 F-150 with Tow Package
2009 Flagstaff 829 FKSS
Prodigy Brake Controller
Equalizer Hitch
renegaderailfan is offline   Reply With Quote
Old 06-27-2009, 07:24 PM   #2
Oakman's Avatar
You probably didn't use as much propane as you thought you did. The real propane usage comes in cold weather when the furnance runs. Your right about the arrow pointing to the tank that is being used. Your other bottle is probably still full.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 06-27-2009, 10:56 PM   #3
rafcar's Avatar
There are some regulators that will automatically pull gas from the other tank if one goes empty. I believe that is what we have in our Cherokee TT. With this type you just aim the arrow down and turn both tanks on, that way it can pull gas from either tank, or you can aim the arrow to either tank, that way you can pull one tank out for refill while the other one still running.
2007 Forest River Cherokee 30F
* 14K Equal-i-zer hitch
* TST tire pressure monitor
2003 Chevy Silverado 2500HD Duramax
* 4" MBRP exhaust
* AFE stage2 air intake kit
* Hypertech III, set on stage1
* back-up camera
* Putnam XDR class V hitch receiver
* Airlift air bags
2004 EZGO custom electric golf cart
rafcar is offline   Reply With Quote
Old 06-28-2009, 08:37 AM   #4
Head Rambler
You have an auto swtichover regulator. You point the arrow at the cylinder you want to be the primary cylinder. The regulator draws propane fom that cylinder until it's empty then it automatically switches to the other cylinder. When the primary cylinder becomes empty the regulator also sets a red flag to let you know that the primary cylinder is empty. At that point you switch the arrow to the other cylinder and remove the empty one and have it filled.
Gotta go campin!
Old 06-28-2009, 08:53 AM   #5
rafcar's Avatar
I thought the arrow pointing down toward the gas line that goes into the TT meant that gas will come from either tank. How does it automatically change over if the arrow is pointing to one tank? Bama, should the arrow always point at one of the tanks then.
* 4" MBRP exhaust
* back-up camera
* Airlift air bags
Old 06-28-2009, 07:28 PM   #6
Head Rambler
You're right, some regulators will draw from both cylinders if the arrow is pointed down. I don't recommend running this way simply because you're emptying both cylinders and when you run out you're completely out.
Gotta go campin!
Old 06-28-2009, 08:32 PM   #7
rafcar's Avatar
That makes sense. I'll run one tank at a time from now on. Thanks.
* 4" MBRP exhaust
* back-up camera
* Airlift air bags
Old 06-28-2009, 08:42 PM   #8
Also dont open both valves that way you are sure you have a full one when the other runs out
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 06-28-2009, 09:30 PM   #9
Chris and Sara
This makes sense, thanks guys!
Equalizer Hitch
Old 06-28-2009, 09:54 PM   #10
dharri770's Avatar
I have always only opened one valve when setting up camp and when I'm heading out, I close it. Are most other folks leaving the gas valves open at the tank all the time and relying on control knobs?
2002 Ford Excursion w/ 7.3 TD, 3.73 rear
2008 Salem 26TBSS
Wife and (3 kids): 10g, 9g, 4b
dharri770 is offline   Reply With Quote
