Old 12-31-2013, 11:08 AM   #11
Old Enough to Know Better
gasman6674's Avatar
32 Years in the LP Gas Equipment business, Gasman fits also.
The pressure type gauges dont work well as by the time the gauge indicates low pressure you are out of gas.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 12-31-2013, 11:31 AM   #12
Denver, CO
garbonz's Avatar
Originally Posted by Carla View Post
I just pour a cup of boiling water down the side of the tank. Where the tank turns cold is the level of the gas. As stated above, if one empties, I fill it before the second empties.
Note that this works ONLY if you use propane at the time of the test. so put your stove on for a couple minutes, before doing the hot water thing. The frost line will show up where the level of propane is.
Kinda of a pain tho
2017 Fuse 23T
Old 12-31-2013, 11:39 AM   #13
Denver, CO
garbonz's Avatar
Originally Posted by gasman6674 View Post
They make a 20# and a 30# valve with a gauge built into it. Check with your local LP Gas dealer to get one installed.
looks like a level gauge to me and not a pressure gauge. Should be VERY accurate. I have one on a horizontal 20 lb tank in my slide in and it really works great. Only one tank in that dude, so it's good to know where you are...
2017 Fuse 23T
Old 12-31-2013, 11:17 PM   #14
Kinda of a pain tho
I beg to disagree. I've never had the gas on while doing the hot water thing. I don't look for frost, I run my hand down the side of the tank where I poured the water. You can feel the temp difference. A cup of hot (boiling) water down the side is easier for me than removing the tank for the weight test.
Carla
2014 A122BH
18 Trips
47 Nights
20 Sites
6655 Miles
Carla is offline   Reply With Quote
Old 01-01-2014, 09:37 AM   #15
Denver, CO
garbonz's Avatar
If you use with the propane on, you get an actual frost line that is pretty precise, more so, in my experience than feeling the tank.
It is much easier than pulling the tank for sure. Potatoe potato
2017 Fuse 23T
Old 01-01-2014, 09:49 AM   #16
Jack of All Trades
RJHuser's Avatar
Gasman:
Do you have a manufacturer name and model number for these gauges, and where they can be purchased?
Cannot find them at our local propane dealers.
Rick
Rick & Debbie; Brandy & Schnoodle (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
RJHuser is online now   Reply With Quote
Old 01-01-2014, 05:59 PM   #17
Denver, CO
garbonz's Avatar
Another idea I just checked out. Used me IR temp gauge that I use to check tire/hub temps (20$ Harbor freight). turn on you stove and shoot the tank side and you can clearly see the line of liquid propane.
Works great.
2017 Fuse 23T
Old 01-02-2014, 08:24 AM   #18
gasman6674's Avatar
I work for the distributor but we dont sell retail. Send me a pm and I will let you know.
Old 03-22-2014, 11:20 PM   #19
Thanks for all the ideas. I just put in an order to Truma for a LevelCheck. Great having so many helpful folks.
JoArt is offline   Reply With Quote
Old 03-23-2014, 01:38 AM   #20
Terier's Avatar
Originally Posted by wrvond View Post
None. When one runs out, I refill it before the second one runs out too.
Same here. Of course being in warmer climate I don't use much propane.
propane
