Old 12-30-2013, 10:37 PM   #1
Propane Gauge
I'm sure by now someone has put a propane gauge on their tanks. Giving them a knock to hear the sounds makes me nervous, we need a more concrete approach.
What propane gauges have you installed.
Thank you.
JoArt is offline   Reply With Quote
Old 12-30-2013, 11:29 PM   #2
Professional Curmudgeon
None. When one runs out, I refill it before the second one runs out too.
2002 Forest River Flagstaff 8528RLS
2014 Coachmen Catalina 253RKS
2016 Keystone Summerland Mini 1750RD
2012 F250 Lariat 6.2L Crew Cab FX4
wrvond is offline   Reply With Quote
Old 12-31-2013, 12:41 AM   #3
Try this
I am having trouble imbedding a URL into this msg. Type this URL into your browser Fill level indicator Truma LevelCheck It is a product called TRUMA LEVELCHECK. Cost about the same as two decent propane guages and portable so you can use it anywhere. In my experiences propane guages do not work. Something to do with the gas not registering. (maybe someone else can explain it better than me) You are already out of gas by time they indicate the low level. I am going to pick one of these up before our summer trip.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 12-31-2013, 12:43 AM   #4
JoArt;
Guess my URL worked, just click on " Fill level indicator Truma LevelCheck" in my previous reply
Old 12-31-2013, 01:42 AM   #5
I just pour a cup of boiling water down the side of the tank. Where the tank turns cold is the level of the gas. As stated above, if one empties, I fill it before the second empties.
Carla
2014 A122BH
18 Trips
47 Nights
20 Sites
6655 Miles
Carla is offline   Reply With Quote
Old 12-31-2013, 06:27 AM   #6
Like others, I just use the other tank and get the empty one filled at the first opportunity. If I really want to know, I weigh the tanks on a bathroom scale. The tare weight is stamped on the tank, so subtract tare from actual and you have the weight of the propane. Want to know how many gallons? At 60 degrees F. propane weighs approximately 4.2 pounds. So, divide the weight by 4.2 and you will know how many gallons of propane you have left.
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 12-31-2013, 07:13 AM   #7
Old Enough to Know Better
gasman6674's Avatar
They make a 20# and a 30# valve with a gauge built into it. Check with your local LP Gas dealer to get one installed.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 12-31-2013, 08:23 AM   #8
The typical pressure gauge you can buy will not provide any useful information. The pressure in the take is temperature dependent until all the liquid is gone, so the gauge will not measure the amount of liquid left. That means when it shows low pressure, the tank is essentially empty anyway. There are side mount temperature gauges that can show the level of the liquid. But these will only work while you are drawing out gas and causing evaporation of the liquid. You must be able to see the side of the tank, and are useless if you have a cover or the tank is not being used.
The best way I've found to manage propane, like others here, is the simple switch over valve. When one tank is dry, you switch to the other and refill the empty tank at your leisure. Also, with very little practice, you can estimate by hand weight whether a tank is close to full or empty. If it is close to empty, refill it. I'd just rather not have another tool to search for or lose just to read the level of the tank for something as trivial as propane. (Wait, did I just say I'd rather not have another tool?)
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 12-31-2013, 09:39 AM   #9
Hey gasman,
On a fishing board that I frequent, there is a guy that goes by "gasman" and I always thought he worked with gas appliances or in the gas business. Then I found out that he is an anesthesiologist! When I saw your name, I was therefore thinking anesthesiologist!
Old 12-31-2013, 10:14 AM   #10
I've bought 3 of these: http://www.amazon.com/Brinkmann-812-9220-S-Propane-Tank-Gauge/dp/B007WH7S4A/ref=sr_1_1?ie=UTF8&qid=1388505876&sr=8-1&keywords=propane+gauges . The first one didn't work. Are they entirely accurate, not really. In my experience, however, they are sufficiently accurate to let you know that you might have enough gas to run the heater through a chilly night. I've also used the hot water method noted above. It works pretty well too.
As to the worth of a gauge - I think it's a matter of personal preference. The tank switching method is probably adequate for summer use. I have the gauges mostly because I like gadgets and, if I ever ran out of gas, my spouse would likely never go camping with me again.
00buck is offline   Reply With Quote
propane
