Propane hose dilemma, help needed
I recently replaced both regulators and pigtails on my 5th wheel. Still have issues with a leak only to discover one of the connectors on the 10'-12' extension hose that crosses from one side to the other is leaking where it is crimped onto the hose. One end has a 1/4" mpt connector and the other end has a 1/4" fif connector. I have looked on the web, called rv dealers, and rv parts vendors but cannot locate the same hose. I can't even seem to locate adapters to make something else work. Has anyone run into this same issue and what did you do or can be done to fix it?
