Old 04-14-2013, 09:34 AM   #1
Propane issue..newbie
Hi guys..just purchased a 2008 Georgetown 373ds privately..whihc is why we are now having issues....didn't test before buying..didn't realise there was so much to test....the propane tank say 2/3 full...we have opened the tank valve..detector flashes green...but no gas appliances work..the unit hasn't been used for a while..is there a propane switch we need to turn other than the detector..? thanks
lorrainechris is offline   Reply With Quote
Old 04-14-2013, 09:37 AM   #2
wyo700's Avatar
How fast did you open your valve on your tank? Try closing and opening very very slowly. Sounds like the over pressure valve is popping. I had this happen to me. If it still doesn't work you could have a faulty OP valve.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 04-14-2013, 09:44 AM   #3
nuisance's Avatar
You probably have air in the lines, turn on the stove and wait until you smell the propane, turn it back off, wait a minute then try to light the burner again, You don't need to do anything the detector. Make sure the propane is turned on at the tank.
Congratulations on the new to you unit...Welcome to the forum.
[COLOR="Red"]Al and Deb
Sugar and Anna Belle
2016 Toyota Tundra
2011 Greywolf 26rl
nuisance is offline   Reply With Quote
Old 04-14-2013, 11:14 AM   #4
hi..thanks for your help....we tapped the selonoid and it is now fine.....one problem fixed...lol...thanks
Old 05-03-2013, 07:21 PM   #5
The solenoid will open with a 9 volt transistor radio battery. Of course you should first remove the wires.
Murf is offline   Reply With Quote
