Old 05-05-2014, 03:47 PM   #1
Propane leak
Whenever i have the tank on the door side open i can smell propane, but the other side works like a champ, i tried soapy water but could not find any leak, i feel like i can smell it the most in the red spot below, was thinking about undoing it and just wrapping some plumbers tape and wrapping the fitting, only noticed the smell on the first trip this year, (Sat in the cold all winter) and when i was trying to find it the other day can turn it on and smell it pretty fast, i even switched tanks and still does it on the door side, If the tape doesnt fix it what what else could it be?
Deeks is offline   Reply With Quote
Old 05-05-2014, 03:51 PM   #2
Doesn't look like any pipe dope or tape is on it. I'd remove all the connections and tape them all.
Old 05-06-2014, 06:17 AM   #3
Use tape rated for gas, last I got was yellow.
If that does not fix smell take camper by local gas serves co and get them to check with sniffer meter to find leak.
Sent from my Nexus 7 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 05-06-2014, 06:36 AM   #4
KyDan's Avatar
Hoses can leak at the crimp too.
I agree that all threaded connections can be removed and taped or
use LP safe pipe dope and re-tighten. I've found more than one threaded
fitting that needed another half or even a full turn. If you smell it,
it's leaking.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 05-06-2014, 08:33 AM   #5
The connection that is in the picture I believe is a tapered fit and should not need thread tape.
ayotte is offline   Reply With Quote
Old 05-06-2014, 08:37 AM   #6
D-maxx dave's Avatar
Be sure and snoop the rubber also. A pinhole is all it takes! Found out the hard way!
David & Kelly
2015 Sandpiper 355RE
2015 Silverado 3500 CCSB SRW 4X4 D-maxx
Nights camped in 2016:03😄
D-maxx dave is offline   Reply With Quote
Old 05-06-2014, 08:41 AM   #7
All pipe, brass or steel, are tapered (with the exception of flare fittings) and need tape or some sealant.
Old 05-06-2014, 08:56 AM   #8
nuisance's Avatar
If you have been towing it and have just stopped it could be what happened to us a few years ago. We where on a trip to Colorado and was flagged down by 3 different cars saying that propane was leaking. SO of course we stopped and checked, smelled something that smelled like propane, checked and tightened all fittings the first two times. On the third time we shut off the propane completely. Went to a get gas and then we noticed that the truck smelled of "propane" what the????? Come to find out the gas in the tank had a higher octane ethanol blend then normal so the truck exhaust smelled like rotten eggs.......After a few more fillups the smell was gone
[COLOR="Red"]Al and Deb
Sugar and Anna Belle
2016 Toyota Tundra
2011 Greywolf 26rl
nuisance is offline   Reply With Quote
Old 05-06-2014, 11:19 AM   #9
SKnight's Avatar
I agree that it needs to be pulled apart and thread taped, but before you touch anything I'd find that leak first. A spray bottle of soapy water might show it, or as mentioned you can take it to a local gas company and they can sniff test it telling you exactly where it's leaking.
That area you indicated could be the hose crimp letting the hose leak, the hose itself, the fittings or even the regulator.
So first things first, I'd find the leak first and foremost.
Old 05-06-2014, 12:01 PM   #10
Old Enough to Know Better
gasman6674's Avatar
All LP gas hoses have a "pricked" cover. All hose permeates the product following thru them some what. Think nitrogen and air in tires. The "pricks" allow the hose to breath and to stop the outer cover from bubbling. Sometimes it will get pricked to deep and actually leak. The crimped ends will also leak sometimes if they are not crimped to spec. I have had brand new hoses leak. Also DO NOT put tape or dope on the 1/4" inverted flare on the end of the pigtail or any flare for that matter as it will cause more issues than its worth.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
leak, propane
