Old 08-22-2011, 09:59 PM   #1
fast murray's Avatar
Propane leak detector
We have a 12 volt LP detector mounted in front lower portion of our 5th wheel. Is it possible for these to become faulty? I've heard it going off while stopped when the gas is on for the frig. Also had it go off in the middle of the night when the water heater was switched on. I don't smell propane and I hosed down most of the connections with soapy water with no results. Any ideas?
fast murray is offline   Reply With Quote
Old 08-22-2011, 10:28 PM   #2
Yes. I just installed a new one and on it's label it specifically states replace every 5 years. Check Amazon.com for a replacement if it is one of the recess mounted ones. If surface mount then any RV store will sell one.
Old 09-11-2011, 10:52 PM   #3
Got one from Amazon that is recessed in the wall and it worked great this weekend. Well, at least it didn't go off!!
Old 09-12-2011, 02:30 PM   #4
You can aim a butane lighter at it, don't light the flame, just press the gas relief, and that should cause it to go off. Some propellant in hair sprays, perfumes, etc., and other stuff will set it off. Also a low battery will cause it to beep on and off.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 09-12-2011, 02:59 PM   #5
BigDTx's Avatar
If you break wind our your pet does close to it, that will set it off. Trust me!
BigDTx is offline   Reply With Quote
Old 09-12-2011, 04:39 PM   #6
Very True
LadyWindrider
