Old 04-06-2014, 11:03 AM   #1
Propane leak while stored for winter
I noticed a strong Propane smell last week. I removed the cover and checked the tanks. Both were empty. I didn't turn the tanks off last fall. Is it normal to loose 1/2 a tank of propane over the winter? We were almost out of propane as our last trip was in the Smokys in November and rather cold. I have refilled the tanks, recharged the system, and closed the tanks. The green/red indicator on the regulator remained green for almost a full day. Propane leak detector has not made a noise. Green indicator light says it working.
John Craig
jrctoby is offline   Reply With Quote
Old 04-06-2014, 11:16 AM   #2
Ford Idaho's Avatar
It is possible I guess for the rubber seals to get cold enough to shrink and let gas leak out.
I guess your tanks are outside so the detector would not indicate a problem as it only goes off if there is a leak "inside" the trailer.
A note to yourself: Post trip check, close gas valves!
Old 04-06-2014, 11:46 AM   #3
Get some soapy water and check every connection and the valve. I think you will find the leak.
Old 04-06-2014, 02:59 PM   #4
Sprayed bubble stuff liberally all over external hoses and fittings. Slight bubbling on one of the hoses so I replaced all of them. New propane and hopefully things are back to normal. I couldn't figure why the detector didn't allert but I guess the only leak was on the outside. May have been leaking for a long time as it was such a small leak. I am usually careful about leaving the propane on after a trip but forgot this time. Something else to add to the close down list for the wife to remind me.
Thanks for the speedy relpys.
Old 04-06-2014, 03:19 PM   #5
cat1956's Avatar
I had a leak one time where the valve screwed into the tank.
Tommy and Wanda
2014 Flagstaff 27RLWS
2017 Ram 1500 5.7 Hemi
Equal-i-zer 1,200/12,000 Weight Distribution w/ 4-Point Sway Control
cat1956 is offline   Reply With Quote
Old 04-06-2014, 03:44 PM   #6
I have 4 tanks between the grills and the camper and have been leak free up til now.
Old 04-06-2014, 03:45 PM   #7
Ford Idaho's Avatar
Glad you got it worked out with minimal fuss and bother.
leak, propane, winter
