Old 07-24-2015, 10:17 PM   #1
trbomax's Avatar
Propane line routing
Is it just me or is this a realy potentially dangerous way to run these lines? If the 1/2" pipe were a foot shorter the lines would not have to be looped forward between the axel and frame.What were they thinking?
trbomax is offline   Reply With Quote
Old 07-25-2015, 08:56 AM   #2
Jim34RL's Avatar
Are you asking about the line that is coming off the male run on the tee? If so I do not see any issue with this line. You do not want a short run; as this could stress the joint at the tee. Sometimes a little flex is better than no flex at all due to vibration of the trailer as it is traveling.
You also need wrench clearance for assembly and holding the tee in place as you tighten the joint.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 07-25-2015, 09:01 AM   #3
Professional Texan
TexasBob's Avatar
As an old instrument fitter it could certainly done in a neater fashion but I believe it is reasonably safe.
Texas Bob
2015 Chevrolet Silverado HD2500 Z71
2013 Prime Time Tracer Executive 2640 RLS
TexasBob is offline   Reply With Quote
Old 07-25-2015, 09:32 AM   #4
trbomax's Avatar
The angle on the pic doesnt show it like it really is. In reality, the 1/2" pipe,the T ,and all the lines are directly between the top of the U bolts and the frame,limiting axel travel at that wheel to about 2".A broken spring would crush all the lines between the frame and spring. Oh well,I guess it just is what it is.
Old 07-25-2015, 09:45 AM   #5
Phat Phrog Stunt Crew
elind's Avatar
You would think that the 1/2" pipe would have been set on inner side of the frame away from the top of the springs. What would happen if a tire ripped apart?
2014 Wildcat 327ck
elind is offline   Reply With Quote
propane
