Old 01-06-2016, 08:11 AM   #1
Propane not flowing from 2nd tank
gas will not flow from second tank. could it be the gr-630 regulator?
jim1225 is offline   Reply With Quote
Old 01-06-2016, 08:32 AM   #2
steelpony5555's Avatar
Had this just happen....I disconnected the regulator hose and switched the valve to the other tank.....reconnected and switched the valve back and then slowly opened the tank valve and the propane flowed ....only happened once and not sure exactly what caused it.....
From Central Texas
2014 Cedar Creek Silverback 29IK
2010 Dodge Laramie 3500 Dually
My Steelpony....2007 HD Ultra Classic...done up in a memorial to the 343 firefighters who died 9/11
Never Ever Forget....yes I was a Volunteer FF for 20 years........
steelpony5555 is offline   Reply With Quote
Old 01-06-2016, 09:48 AM   #3
Head Rambler
Sometimes the excess flow valve will close when you turn the cylinder valve on too fast after reconnecting it. Close the cylinder valve loosen the nut, then retighten the nut and slowly open the cylinder valve. That may solve your problem.
Gotta go campin!
propane, tank
