06-27-2013, 10:28 AM
Propane not working
Was cooking the other nite and tank ran dry. Switched over to other tank, which is full. Monitor showed green. Lit the grill, ran for afew minutes ans went off. Monitor was red. Went back, turned tank off, anf reopened very slowley. Same result and smae thing this morning.
Anybody know whT is going on?
Rick and Linda, Lindale, TX
2011 Flagstaff 8528 CKSS
2006 F350 SW
Camping nights 2013: 130
Camping nights 2014: 17
06-27-2013, 11:01 AM
Engineer of Crazy Train
I would keep both tanks on and let the auto switchover do it's job. But I had situations like what you said on a full tank before. I usually fool with it and tap it on the ground and see of the OPV is stuck. My 5lb tank is notorious for it.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 - 18
Come read my Camping Blogs
06-27-2013, 11:39 AM
I guess if i leave the switch in the center it will pull from both tanks. Normally i move it from one side to the other when a tank empties. Ill see what happens ig i center it. Ill try the tapping
06-27-2013, 11:46 AM
Old Enough to Know Better
Auto change over regulators work on inlet pressure. When the inlet pressure falls below 10 psi it will switch to the "full" tank. All the handle does is switch the indicator. If you put it in the middle you might not get any fuel. I am confused when you say monitor/alarm was green/red do you mean the gas alarm? or does your rig have a gas level detector?
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle.
2020 Keystone Cougar 364BHL ,Gone 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
06-27-2013, 12:16 PM
Always Learning
This took me a while to understand, to be honest. I ended up writing up a refresher for myself.
Understanding My Automatic Propane Changeover
It is a gas level indicator
2006 F350 SW
06-27-2013, 12:24 PM
Mine does not look like that. Has a lever that moves from one side or the
Other to select the tank. Dont know how to get a picture on here.
2006 F350 SW
06-27-2013, 12:30 PM
You may have a manual change over valve. A little strange but possible.
To post pictures when you reply use the go advanced tab, then select manage attachments and click browse and browse your computor for the picture, click upload your done.
06-27-2013, 02:31 PM
I had the same problem,turned out to be the hose.I hooked the full tank to the other hose and it worked fine.Replaced the hose and all was well.
09grizzly1
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
06-27-2013, 08:06 PM
09grizzly1
Ill give that a shot
2006 F350 SW
