Old 10-21-2012, 02:34 PM   #1
wfmdfm's Avatar
Propane Pigtail
Another cold night another failed pigtail. I have replace pigtails on both tanks and it seems that its time to replace another one. Any idea if one pigtail make is better than another? I would pay double for one to last a little longer.
Wally
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 10-21-2012, 02:49 PM   #2
TURBS's Avatar
Wally
Why is it that your replacing them?
Old 10-21-2012, 03:15 PM   #3
wfmdfm's Avatar
Loss of pressure in the system. I will have a green indicator until I use the system then it turns red and the pressure is lost. When I have replaced the 2 pigtails it has solved the problem.
Wally
2015 Toyota Tundra
Old 10-21-2012, 04:56 PM   #4
TURBS's Avatar
Wally
I'm not sure your pigtails are the problem.
Have you read my thread "propane fyi"
Turbs
Old 10-21-2012, 06:12 PM   #5
wfmdfm's Avatar
Did did read that but I assumed that when you said froze you were talking out frost. So you think the auto swap did not operate all the way?
Wally
2015 Toyota Tundra
Old 10-21-2012, 06:16 PM   #6
Fire Instructor's Avatar
It may just be a bad regulator, but my auto-swap only swaps properly about 50% of the time. I was thinking that the malfunction was caused by the auto-swap closing and opening too quickly, and this closes the safety valves in the pigtail.....
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 10-21-2012, 06:34 PM   #7
wfmdfm's Avatar
Well maybe it is the swap. It did swap some time during the night. I will mess with it tomorrow and see what I find.
2015 Toyota Tundra
Old 10-24-2012, 09:45 PM   #8
TURBS's Avatar
Any results?
