Old 09-15-2013, 02:19 PM   #1
Propane smell from furnace
I have a 2012 banshee B2 and up until recently haven't really used the furnace. Bought the unit brand new about 2 months ago.
Every time I use the furnace, it has a very strong propane smell... The gas detector in the trailer doesn't go off or anything, but there is definitely something not right. Is almost as if the furnace is burning all the propane. I tried closing the tank valve 3/4 way to see if that works, but doesn't seem to make a diff.
Any suggestions?
Thx
Kawigreenguy is offline   Reply With Quote
Old 09-16-2013, 11:28 AM   #2
Old Enough to Know Better
gasman6674's Avatar
Have your dealer do a leak check, You could have a loose connection between the control valve and the burner (most likely), or It could be delayed ingnition (gas build up) do to improperly adjusted ingniter. Do you hear a woof noise? either way it should be covered under warranty
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 09-16-2013, 10:21 PM   #3
Thanks, ill get my dealer to check it out.
