Old 08-04-2014, 11:44 AM   #1
Propane smell outside
All our hoses seem to be intact on the front of our shamrock 21ss a very strong propane smell exists outside our trailer near the tank. We were told this is normal, but I can not imagine this is normal or safe. Any guesses what this could be or where and what to check?
5andadog is offline   Reply With Quote
Old 08-04-2014, 01:19 PM   #2
Old Enough to Know Better
gasman6674's Avatar
Its not normal. Mix up some water and dish soap and brush or pour it on your tank valves, connections and regulator . When you see growing active bubbles there is your leak. If you do not feel comfortable doing this shut off your tank valves and then that it to an LP Gas Dealer or RV dealer for repair.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 08-04-2014, 05:36 PM   #3
Agreed, it's not normal or safe. We had a similar situation on our 2014 Rockwood A122 on our first trip. I suspected the regulator, or in that area, after extensive search and checking fitting for tightness. Dealer found a bad casting where the hose from the regulator attached to the pipe running under the camper.
Fred W
Old 08-04-2014, 05:55 PM   #4
Ford Idaho's Avatar
Absolutely no way is a propane smell/ leak "normal" and IMO anyone who says it is should be duct taped to a mad Rhino.
This.
Old 08-04-2014, 06:07 PM   #5
sammonilla's Avatar
I would tell they guy that told you that it is normal to find the leak himself with a lighter!!! No leaks are normal in in a LP system. Soap water and some time will show you where the leak is. Most are pretty easy to fix.
Scott Sammons
Woodinville Wa
GO SEAHAWKS!
2016 SILVERADO 2500HD 6.6 Duramax
2012 280BH Casscade
sammonilla is offline   Reply With Quote
Old 08-12-2014, 08:30 AM   #6
mTn_biKer65's Avatar
I had a similar situation on my previous trailer. Tried spraying some leak detector on all the connections and regulator without success so I replaced the regulator and the smell went away.
Good luck.
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS -
2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
mTn_biKer65 is offline   Reply With Quote
Old 08-23-2014, 05:11 PM   #7
I just replaced the hose from the tank splitter to the black pipe underside trailer. In this case there was a bulkhead fitting that passed through the front frame of the trailer. The flexible hose with an ASE flare fitting was cracked because the hose had to bend up over the tank tray putting pressure on the fitting. Leak was right at this bulkhead and difficult to detect.
Areid is offline   Reply With Quote
Old 08-23-2014, 05:22 PM   #8
Oaklevel's Avatar
Our son had a brand new tank that had a leak at a weld on the tank itself. The dealer replaced it.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 08-23-2014, 05:23 PM   #9
davel1971's Avatar
who ever told you that was normal, never take advice from them again
David & Lynn
propane
