We have a Coleman 9941A series stove and hooked it up to the quick connect gas fitting on our camper. There was a low flame, but not enough gas pressure to make a high flame.
Had CW check out the propane pressure and they say it's ok. They think the problem is the second regulator on the stove. If we can hook the hose directly to the stove w/o the regulator they think it should work. Here's a picture of the Coleman regulator:
http://www.appliancefactoryparts.com...&modelsID=8334
If you click on the second picture from the top you can see the female connector on the regulator. It has a pin down inside of it the allows the gas to flow to the burner when tightened down.
We need to find that type of female fitting. It appears to be 3/8's, but so far no gas or camping store has been able to find one in a catalog.
We would like to couple the connector with another quick connect fitting.
If anyone knows where to locate the fitting or how to adapt the one on the regulator, please let me know.
