Old 12-05-2014, 09:56 AM   #1
LKicklight's Avatar
Propane Supply tank
Yesterday we had a 100 gallon propane tank set up at our Sunnybrook. After the installation, the tech's were doing there usual leak checks, what they found had nothing to do with the installation of the tank. There leak detector found a leak at the furnace supply valve. This coach is 11 years old and this is the first ever problem we have ever had. The valve is leaking around the valve an not into the chamber. New valve ordered and will be installed tomorrow.
Sunnybrook is an 03' model and we are the original owners..
kickster
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 12-05-2014, 11:53 AM   #2
You're going to love the 100 gallon LP tank. We had one installed a couple years ago and can get through more than a season with it depending how much we use the furnace. The spring and fall temps can get a little cool up here in Wisconsin. The installer buried the line running to the camper so the guy that empties our septic tank won't trip on it. He hooked it up so we still have one of our 30's as back up.
Old 12-13-2014, 09:47 PM   #3
Jimmerinwi's Avatar
Have a 250 pounder at the campground were at in northern Wisconsin. We got 2 years out of it before we had to fill it this year. Luckily missed the spike of prices last year due to the shortage. Granted, we're not there much in winter like we used to be but still nice to not have to worry about running out.
Somedays I wake up Grumpy, somedays I just let her sleep......(Ray Scott)
Some days I wake "Grumpy", Some days I just let her sleep......(Ray Scott)
Jimmerinwi is offline   Reply With Quote
propane, tank
