Old 01-10-2015, 11:50 AM   #11
OK, I saw another Forester the other day with an auxiliary tank connected to it so I thought I would give it a try. Thank You Fonzie
carlcaudill is offline   Reply With Quote
Old 01-10-2015, 01:24 PM   #12
with the belly tank and all , it kind of sounds like you are set up for liquid and not vapor-------the 20# are vapor only---------I know when I hooked my liquid propane generator to a 20# keg it only ran for a minute or two then died
Might be worth checking out
Spike
47chevy is offline   Reply With Quote
Old 01-10-2015, 02:55 PM   #13
propane problem
When I had the extend a stay installed on my class C I was advised that it was necessary to open the valve on the second cylinder "SLOWLY" . That if you opened it to fast the safety device would see it as a leak and shut down the flow.
john.tucson is offline   Reply With Quote
Old 01-10-2015, 03:26 PM   #14
RPAspey's Avatar
temperature is not the problem....I wish it was 60 here!!!! Is your propane gauge aftermarket or built into the tank? I had problems with an aftermarket gauge on my backyard grill. Just didn't let the gas thru. Try removing it if you can.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 01-10-2015, 10:28 PM   #15
ramair's Avatar
My understanding that that T in the line is for a BBQ or some other device its an outflow connection and not a connection to connect incoming. On our Class A I have a extend-A-Stay installed and it was installed before the regulator and is a quick connect. You have to turn off the main tank and then you can connect the aux tank. I have ran our MH off a BBQ 5# tank and has worked great. I think you need to talk to a Propane specialist.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 01-11-2015, 07:22 AM   #16
After a little more research I have found out that what I have is called an extend-a- stay connection which is made for connecting auxiliary fuel tanks to your RV system. It also has a connection for connecting a grill. I still do not know why mine is not working. ANY SUGGESTIONS. Thank to everyone
class c, propane
