Old 01-09-2015, 10:35 AM   #1
Propane system on class c
I have a 31' Forester class c and every thing works fine with the under belly propane tank but if I connect a 20lb tank it does not work. Every thing will light but will not continue to burn. Is the 20lb tank to small or do you think it could be another problem.
carlcaudill is offline   Reply With Quote
Old 01-09-2015, 11:56 AM   #2
Size shouldn't matter.
A leak in one of the lines could be allowing the pressure to drop below a critical level. Or the regulator may have failed (that would be the first thing I would check). It could be pretty easy to diagnose the regulator by removing it from the RV and hooking it up to your backyard BBQ (assuming threading is the same, etc.)
A regulator that allows too much pressure through would be a problem just as much as (if not more than) one that is too restrictive.
davido_ is offline   Reply With Quote
Old 01-09-2015, 05:13 PM   #3
RPAspey's Avatar
What's the outside temperature where your rig is at? If its cold enough, the 20# bottle isn't going to be able to put out enough propane to maintain pressure. heck, a 30# probably would work either.
You see, the colder the tank is, the harder it is for the propane to vaporize thus why you can light but not maintain a flame. A larger tank will have a larger diameter this more surface area and consequently more available gas vapor.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 01-10-2015, 08:22 AM   #4
The temperature was about 60 when I was working on the system. I thought it was the tank so I tried another tank and it done the same thing. The gauge that shows how much propane is in the tank is new and will hold in the green until I light the water heater then it drops to bottom red. The hose to the RV is old so could it be clogged.
Old 01-10-2015, 08:53 AM   #5
fonzie's Avatar
Where are you connecting your 20 lbs propane tank on your RV?
Fonzie
Old 01-10-2015, 09:23 AM   #6
There is an auxiliary tank connection on the main line from the under belly tank.
Old 01-10-2015, 10:00 AM   #7
fonzie's Avatar
Has this work before with portable tank?
Fonzie
Old 01-10-2015, 10:11 AM   #8
Be careful guys. As a retired Fire Chief, propane is one of the most dangerous things to work with. Seek expert advice from a propane-certified technician. Lines may be clogged.
Bob & Sue Rowan
Okeechobee, FL
2012 Coachmen Mirada 29DS (SOLD)
2015 Keystone Bullet Travel Trailer
2016 F-150 Lariat with Auto Trailer Backup
Dog = Morki (Yorkie-Maltese) - Zoe
Malabarbob is offline   Reply With Quote
Old 01-10-2015, 11:03 AM   #9
Never used it before but that is what it is made for
Old 01-10-2015, 11:23 AM   #10
fonzie's Avatar
OK, just asking, as some of these are for feeding exterior appliances only.....hopefully someone with same setup will chime in to help.
Fonzie
class c, propane
