Old 06-05-2014, 02:07 AM   #1
Camper Extraordinaire
shark918v's Avatar
Propane System Testing
Q: I own a 2001 FR 1610 pop-up trailer. How do I test and check the propane system for leaks and proper functioning?
shark918v is offline   Reply With Quote
Old 06-05-2014, 08:19 AM   #2
Old Enough to Know Better
gasman6674's Avatar
Mix up a solution of dish soap and water and "soap" all of the connections while the system is under pressure but all applianaces are off. If you get growing bubbles you got a leak.
Hope this helps
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 06-05-2014, 08:20 AM   #3
DaveSchwartz's Avatar
Needless to say (I hope) is you do NOT use a flame to check for leaks. I use a soapy-water solution in an old spray bottle.
'Proper functioning'? Turn on your gas appliances and see if they work. Also, try them all at the same time to see if your regulator can maintain flow (make sure you have a full tank at normal temperature). If you're just out of storage it may take a while for gas to get through the whole system... I turn off my tanks for winter storage and it usually takes 20 or 30 seconds to get from the tanks on the front to the fridge/stove midships and then a few more 'pilot out' failures to light the water heater at the back.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
propane
