Old 06-10-2012, 07:48 AM   #1
cat
propane tank bracket
pulled tanks today to ck them,plate that the tanks set on was very rusty. removed plate and frame also rusty , might want to ck and see this tt is only 1 year old
cat is offline   Reply With Quote
Old 06-10-2012, 07:58 AM   #2
sherdep's Avatar
What trailer do you have?
You must live in a snowy area where the roads are salted heavily.
I inspect my stuff when I wash my trailer and when I remove the tanks to get them filled.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 06-10-2012, 08:10 AM   #3
You must live in a snowy area where the roads are salted heavily...
Don't think so, North Carolina.
The bracket was probably loose or the bottles loose and rubbed the powdercoating off the bracket and paint off the frame. Remove the rust, repaint, put a thin rubber pad under the bracket and install more screws into the bracket/frame.
Old 06-10-2012, 08:26 AM   #4
sherdep's Avatar
how do you know he doesnt live in a heavily salted area?
they do salt the roads in North Carolina to I think -
I guess living in Florida has put me out of reality when it comes to snow and salting the roads
metal on metal friction could cause it - but without pictures cant see how bad it is
Old 06-10-2012, 08:37 AM   #5
His profile says NC and it is rare to have the roads salted when most folks in NC are towing campers. Only snowbirds from the rust belt have to tow campers on salted roads.
Old 06-10-2012, 08:57 AM   #6
Mine was the same way. When I took the plate off the frame it still had the metal pieces between the frame and the plate where they drilled the holes to mount it. So that is what started the rust.
Paul & Karen and the 2 Little ones in tow.
2007 Nissan Armada LE
2012 Wildwood 26BH XLite
20 Nights campled in 2011.
25 Nights Planned for 2012!
pandkm is offline   Reply With Quote
Old 06-10-2012, 09:37 AM   #7
cat
its a fr salem, ultra lite. i sanded it real good , painted it with a good primer, then sprayed it with truck bed liner, should hold real good . yes we get lots of salt on the roads in the winter , but never towed in the salt
Old 06-10-2012, 09:53 AM   #8
How many screws are holding it to the frame? I would make sure there are at least 4 or more. I found out years ago that 2 or 3 just don't keep the bracket tight to the frame
Old 06-10-2012, 10:04 AM   #9
cat
it has 6 , 3 per side
Old 06-10-2012, 10:54 AM   #10
That's good, all of mine just had 2 and I added 2 to ea side to make 6 also.
