Old 11-28-2011, 07:41 AM   #1
Propane tank "clicking"
20 lb tank, rpod 177. Whenever we use propane we hear a clicking noise. Seems to come from regulator. Everything works fine. Don't know what is causing it and whether it is a problem? As always thanks for wise advice.
tomcamper is offline   Reply With Quote
Old 11-28-2011, 07:59 AM   #2
MtnGuy's Avatar
I could be the check valve(s) on the pigtails. See if you can isolate it to 1 side or the other to figure out which pigtail it might be.
I had both of my pigtails replaced under warranty because the "sang" when I was using propane.
Old 11-28-2011, 08:44 AM   #3
propane tank clicking
Thanks mtnguy, but I forgot to mention no pigtail, just a single tank.
Old 11-28-2011, 10:36 AM   #4
MtnGuy's Avatar
Oops. Does the regulator connect directly to the tank ??
