Old 08-21-2013, 04:29 PM   #11
DF5.4's Avatar
I use the hot water trick (pouring on the tank not DW yelling from the shower) and an infrared thermometer. i also make sure the tank is in the shade.
Doug
2011 Prime Time Tracer 3000BHS
2007 Ford Expedition
Reese Dual Cam HP Hitch
Nights Camped 2015-5 in TT
DF5.4 is offline   Reply With Quote
Old 08-21-2013, 04:34 PM   #12
TURBS's Avatar
Maybe this has been said but I leave one tank on and one tank off.
When tank (a) runs out I turn on tank (b) then refill tank (a) repeat repeat repeat.
Turbs
Old 08-21-2013, 04:37 PM   #13
DF5.4's Avatar
Turbs
The problem I have had with that is it will run out in the middle of a cold night.
Doug
Old 08-21-2013, 04:37 PM   #14
QCCowboy's Avatar
Turbs
X2.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 08-21-2013, 04:42 PM   #15
TURBS's Avatar
Done that !
Only happened once .
Got up and switched tank.
When it gets time to run furnace and its that cold both tanks are topped off before fall .
30 lbs will run a months worth of weekends.
I've been around my tanks enough to know when there low-ish.
I'll also turn the full one for the night if its that low.
Turbs
Old 08-21-2013, 04:49 PM   #16
5erDriver's Avatar
The Brookstone store has a gauge that goes on the tank outlet and then you connect the hose fitting to it. A simple visual circular gauge. Not sure on price.
I've seen the stick on types but seem you have to apply heat to get the reading.
Mine is automatic switchover with a window showing when they are empty. Just check periodically and fill the empty one and so on.
2013 Sandpiper 365SAQ
2008 Ford F350 Super Duty
6.4L Powerstroke Long Bed CC
5erDriver is offline   Reply With Quote
Old 08-21-2013, 04:50 PM   #17
Cowboy 54's Avatar
Your gage should be automatic switch over !
Cowboy 54 is offline   Reply With Quote
Old 08-21-2013, 04:52 PM   #18
Cowboy 54's Avatar
[QUOTE="Cowboy 54;449955"]Your gauge should be automatic switch over !
Old 08-21-2013, 05:04 PM   #19
TURBS's Avatar
Mine is auto switch over.
But unless you "look" you never know when it "switched" over.
Turbs
Old 08-21-2013, 05:09 PM   #20
Cowboy 54's Avatar
You have to check once in a while
propane, tank
