Originally Posted by DF5.4
And we are back to the original question. What's the best way to check the level in a tank?
the best way is to weigh the tank.
if you cant weigh it, then replacing the valve with a float level will work.
pressure gauges do not show the level. they only show the pressure in the tank which varies with ambient temperature.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
