Old 07-19-2016, 11:46 AM   #1
Propane tank mixer?
I have a TT and have two 20lb tanks on the front. There is what looks like a mixer and regulator on the top of the tanks.
It has a level i think with green/red gauge on it and a lever.
What does this thing do? Adjust the amount of gas from each tank or something?
jchiar is offline   Reply With Quote
Old 07-19-2016, 11:51 AM   #2
172av8r's Avatar
It's an automatic switch. I don't know if you have the same one as me, but mine works like this: (and yours is probably similar)
When the dot in the middle is green, the rv is feeding off the propane on the green dot side. When that tank runs out, it automatically switches to the tank with the orange dot and the dot in the middle changes to orange to let you know it has switched. You now know you have only one tank and need to get the other one filled.
Manually move the handle to the 2nd tank, and it becomes the 'green' one and will draw off that one, and switch back to the first when it runs out.
2013 Rockwood Roo 23SS
2003 Ford F150 4.6L V8
172av8r is offline   Reply With Quote
Old 07-19-2016, 12:06 PM   #3
Ahh. So you keep both tanks in the open position then?
Old 07-19-2016, 12:46 PM   #4
yes
latner is offline   Reply With Quote
propane, tank
