Old 09-14-2013, 04:15 PM   #1
Norman - Ann's Avatar
Question propane tank noise.
Is it normal for a propane tank to make noise when the furnace or hot water heater run?
Norman - Ann is offline   Reply With Quote
Old 09-14-2013, 04:29 PM   #2
tanddc's Avatar
Yes. Our tanks make all sorted of noise. Almost sounds like music sometimes. I can almost tell what's running by the sound it makes.
tanddc is offline   Reply With Quote
Old 09-14-2013, 04:52 PM   #3
Normal for us. We also have the same noises from the tanks when a propane appliance is running and using propane - especially the water heater and furnace.
2010 Surveyor 294
2006 Ford E-350 Van 5.4
surv294 is offline   Reply With Quote
Old 09-14-2013, 05:09 PM   #4
Iggy's Avatar
Suggestion.
Are you sure it isn't coming from the pressure regulator.
I would suggest turning off the tank valve and then slooowwwly open it.
Their is a small valve inside the rubber hoses that sometimes gives problems.
Try it it won't hurt.
Iggy
Old 09-15-2013, 08:16 PM   #5
Canadian Member
itat's Avatar
Mine made a chirping noise when I first got my trailer. I had to replace the "pigtail" hoses between the regulator and the tanks. Check this thread Propane Tank Noise
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 01-08-2014, 05:31 PM   #6
Our 2014 Roo 23IKSS that we bought in July had this problem also. I called our dealer about it and was told that Forest River had this problem with some of the units that the regulator was louder. They replaced the regulator and hose pig tails in warranty and that took care of the problem completely.
RCCS is offline   Reply With Quote
Old 01-08-2014, 05:40 PM   #7
OL Creeker's Avatar
Here's the fix: replace the regulator! How do I know this? Because while at the factory with our CC that's what the mfg rep told them to do. We had that problem.
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 01-12-2014, 08:33 PM   #8
Moose509's Avatar
I have the same issue with the driver side tank only on our 2011 Palamino Sabre 31 RETS. Have replace the pigtail, no difference. Where can I order the 30# regulator? Looked at Camping World and local propane dealer with no luck. Any help out there?
Moose509 is offline   Reply With Quote
Old 01-12-2014, 08:51 PM   #9
OL Creeker's Avatar
I would suggest you contact the mfg of the pigtail. They were the ones who told FR while we were there, to replace the reg.
Duramax/Allison
Old 01-13-2014, 05:21 PM   #10
MtnGuy's Avatar
My propane system "sang" also.....didn't recognize the tune.
Both pigtails were replaced under warranty, and no problem since.
propane, tank
