Old 10-22-2018, 08:26 PM   #1
Propane tank question
Hi folks has any one use an adapter to be able to use a 100 lb tank on a tt. We found out we will need stay in ours for awhile this winter. Any help will be greatly appreciated. Thank you in advance.
Retired
2013 Tundra 5.7L with tow package
2016 Shasta Oasis 26rl
PaPaMooseP is offline   Reply With Quote
Old 10-22-2018, 08:56 PM   #2
it's done all the time. check with the park manager to see if they allow it and if there is a propane company that makes deliveries. if so contact them and i'm sure the can supply the tank, hook it up for you, and fill it.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is online now   Reply With Quote
Old 10-22-2018, 09:24 PM   #3
Thank you. But I 'll be at my house.
Retired
Old 10-23-2018, 05:53 AM   #4
so call the local propane company and see what they can do. they can supply a tank. do you already have the tank at home? if so a local plumber would be able to hook it up. you want to ensure that any hook-up is in compliance with any concerns the propane company has so that they will still be able to refill it.
Old 10-24-2018, 09:34 AM   #5
What size tank(s) came with the tt? You'd be much better off changing over to a remaining full tank and filling the empty tank at a store such as Tractor Supply. Don`t ever wait to fill two empty tanks. I did that for 9 months while waiting for my new house to be finished.
Schvarak is offline   Reply With Quote
Old 10-24-2018, 09:41 AM   #6
I already have a tank.My tt came with 20 in tanks.The one plumber we have in the area said he won't do anything with it.
Retired
Old 10-24-2018, 10:46 AM   #7
20 is unbelievably small for a tt tank. Mine came with 2 40lb tanks. Each lasted for almost a week in cold weather. 40 lbs is easy to handle. Show us a picture of your existing propane tanks and their bracket. Assuming you have connectors for 2 tanks.
Old 10-24-2018, 10:53 AM   #8
40# Tanks? Not very common from Factory! Youroo! !
Old 10-24-2018, 11:25 AM   #9
Fulltime family RVer
Would this do it?
https://www.etrailer.com/p-100019-24...ils=.questions
Personally, I'd contact a local propane company and would pay for the service call for them to come out, hook up my tank, and then leak test it. But I'm chicken when it comes to things that can explode.
Old 10-24-2018, 10:25 PM   #10
Thank you folks
Retired
propane, tank
