01-15-2015, 09:58 PM
Always Learning
Propane tanks and lock doors / moved
I thought I read that propane isn't supposed to be locked up from a fire/fire department perspective. Well, the door to it, at least. Like they are supposed to be able to get to the knobs to turn it off if needed in an emergent situation.
01-15-2015, 10:01 PM
I guess if the gas needed to be shut off in an emergency, he'd be SOL!
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
01-15-2015, 11:05 PM
Originally Posted by Tx_Rider
I replaced the non locking outside compartment door latches with locking ones.
Now my battery, generator and propane compartments are locked up.
Hate to jump on the bandwagon, but it's illegal to lock the doors, you can lock the tanks but the fire department has to be able to turn the tanks off during a fire.
01-15-2015, 11:18 PM
Thanks for the concern about the propane.
There are two latches, one is a lock and the other is a non locking latch.
When in storage the tanks are off and the compartment is locked, when I am using the RV I will leave it unlocked.
2015 Thunderbolt XLR 340X12HP
2019 Ford F350 KR, 6.7, CC, LB with B&W Companion
US Army Retired
01-16-2015, 07:17 AM
Infractee
That is exactly what I do
01-16-2015, 07:37 AM
If someone needed to get to the tanks.It not that hard to get into a lock door if there was a emergency.
2007.5 Chevy 3500Ltz cc lb Duramax
2010 Sandpiper 345 RET (SOLD)
01-16-2015, 12:29 PM
You remember that when the fire department is letting your stuff burn because they can't turn the LP off.
There's reasons for these things. Trust me, they'll let it burn, talk to any firefighter, if there's something that compromises their safety they'll happily stand 50 feet away spraying water keeping other stuff from catching.
Yes, it's easy to break through the door. Once the fire is going the 1/4" hose blowing LP is insignificant. But it's part of their training.
01-16-2015, 12:39 PM
Infractee
Not trying to be argumentative, just providing a counterpoint of my reasoning.
1: If you are inside a burning camper, I do not believe the FD will be looking for the LP tank valve before they go in and get you and subsequently leaving you to die because you have a CH751 holding that door closed. Their fire axe would make quick work of that door if they were concerned about it.
2: If I am out of my camper and it is burning, pull up a chair and relax, that is what insurance is for. I certainly would not want FD or anybody else try to play hero to save it, it is well insured and far too easily replaced.
01-16-2015, 12:59 PM
I'm with you Rhozeta, by the time the fire department gets there, I don't care. Let it burn.
These things go up fast in a fire. If your not already out, your in big trouble.
I'm curious sknight when you say it's illegal to lock the propane, would that be state or federal law. I would love to see your source.
Jay & Maria - Camp Dog Joplin
2018 Cedar Creek Champagne 38EL
Fulltimers since May 2018!
2017 Ford F350 Crewcab Dually Diesel
Officially homeless and loving it.
Ham Callsign K9NDY
01-16-2015, 01:18 PM
It's so easy to sit back and speculate about what the fire department should and shouldn't do.
I worked closely with public service for many years, they adhere to their training, if they pull up they're not going to pull up a chair with you and watch it burn.
Here's the official NFPA code 58 PDF, pg 48, paragraph e, point 1. You can search the document for "Lock" and find more guidelines.
(e) Appliances installed within vehicles shall comply with
the following:
1. If in the cargo space, they shall be readily accessible
whether the vehicle is loaded or empty.
2. Appliances shall be constructed or otherwise protected to
minimize possible damage or impaired operation due to
cargo shifting or handling.
3. Appliances shall be located so that a fire at any appliance
will not block egress of persons from the vehicle.
(f) Provision shall be made in all appliance installations
for a supply of outside air for complete combustion.
(g) A permanent caution plate shall be provided, affixed
to either the appliance or the vehicle outside of any enclosure
and adjacent to the container(s), and shall include the following
items:
This is the link to the PDF.
http://www.google.com/url?sa=t&rct=j...83829542,d.eXY
Leave armchair quarterbacking for Sunday. There are rules and reasons for everything.
Actually, this is hilarious. If your weight goes one pound over your tow rating you're an overloaded idiot and god help you if you so much as touch one of MY family members.
But lock the doors, against code specified by the NFPA? Pishaw, I'll sit back having a cold one as it burns with my insurance agent on the line telling them where to send the check. They'll never know I locked the tanks against code.
01-16-2015, 01:23 PM
Infractee
Did you miss the part about leaving it unlocked when the tanks are on while camping and only locking it when valves are closed and camper not in use?
I would be on the phone with my insurance agent tho, telling them where to send the adjustor to inspect the burned out carcas that used to be my camper. Would not need to tell them where to send the check, they have my address on file.
01-16-2015, 01:28 PM
Call your insurance agent and tell them that, see what he says.
Look, whitewash it all you wish. The doors don't have locks for a reason, there are other methods to secure the tanks that don't violate NFPA guidelines.
I provided the document. The end, I'm not going to feed you any longer.
01-16-2015, 01:53 PM
SKnight this will be my last post on the issue because it is obvious that you get very upset if someone does not agree with you.
It is important to point out that what you sited as law is not LAW at all. It is standards and code. I understand that this is what industry uses to protect consumers but you said it is against the LAW AND THAT SIMPLY IS NOT TRUE!
You have a wonderful day.
Ham Callsign K9NDY
01-16-2015, 03:32 PM
I believe in every state locking the propane tank is a violation and carries a fine.....though the chances of them catching you are slim....still I don't see the use in that you can do almost everything you need too tank wise on a MH from underneath if even your trying to protect it from theft....though I suppose if you have the canisters that perhaps is worth while though still illegal.
WDK
01-16-2015, 03:42 PM
Incidentally though I was not shown the standard where I live.....I was told this by a fire department captain who came out to inspect my coach because I did have a propane leak....though I am sure locking it is punishable if they wanted to pursue it just like that little tag on your mattress that says "do not remove" secondly if it was found to be locked and there is damage to life or property of your neighbor it's not that it would only take a second to chop it open that matters but how much the law suit is going to cost you because of the violation.
WDK
01-16-2015, 05:27 PM
SKnight: in post #2631 you quoted:
"(e) Appliances installed within vehicles shall comply with the following:
whether the vehicle is loaded or empty."
When I searched for it in your PDF, it was on page 45, not 48, under section 3.8.4. You seem to have conveniently missed the first part of section 3.8.4 on page 44:
"3-8.4.1 The term appliances as used in this subsection shall include any commercial or industrial gas-consuming device except engines."
I don't think gas bottles consume gas, they store gas.
Also, there doesn't seem to be anything that says "readily accessible" means it can't be locked.
So I'm not convinced yet.
And having seen a camper go up in flames, I'm pretty confident that no fire department will ever get to a campground before it's a smoldering heap.
2011 Traverse LT, 3.6L, FWD
01-17-2015, 02:24 PM
The NFPA sets rules that are adopted by the states and federal government as one of the so-called "consensus standards." NFPA 1192: Standard on Recreational Vehicles, is the standard appropriate to this discussion. The standard reads: 5.1.6.2 Securing LP-Gas Cylinder Housings.
5.1.6.2.1 Doors, hoods, domes, housings (or portions of
housings), and enclosures required to be removed or opened for
replacement of cylinders shall incorporate means for clamping
them in place to prevent them from working loose during transit.
5.1.6.2.2 Hoods or housings covering valves shall not be equipped
with locks or require special tools to open.
5.1.6.3 Valve Access Doors and Panels. Doors or panels providing access to valves shall not be equipped with locks or require tools to open.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
01-17-2015, 02:40 PM
x2 Fire Marshalls can and do enforce NFPA standards and can impose fines, also some NFPA standards have also been adopted by OSHA. (Not the ones inquiring about).
As has been mentioned there is a reason the propane access door do not have locks. I'm sure if the was an injury & a locked propane door was involved I sure a lawsuit would be forthcoming.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
01-17-2015, 02:57 PM
Alot of misinformation in this entire thread............
Not trying for an argument but..........
NFPA, ANSI, and other consensus standards while it is true in themselves are not always law (Many are Law). But enforcement agencies such as Fire Marshals and OSHA can site ANY of them when the need requires it. So in effect yes they are law. OSHA of course only against employers.
1966 Mustang GT
1986 Mustang SVO
01-17-2015, 03:43 PM
I just duct tape the doors. No worries! LOL
