Old 12-25-2014, 03:39 PM   #11
trbomax's Avatar
Originally Posted by jonnys_walkers View Post
I can run the propane heater parked in the yard uninhabited and the windows and walls are covered with moisture, not from cooking or people breathing.
When boondocking dehumidifiers are not an option.
Thanks for the input.
I would look for a leak or rust out in the heat exchanger or where the exhaust on the furnace connects to the wall exhaust.Of course to pressure test the heat exchanger you will have to remove the furnace and the sheet metal around it.
trbomax is offline   Reply With Quote
Old 12-25-2014, 03:42 PM   #12
jonnys_walkers's Avatar
I guess I should have mentioned we live in the rainforest where our annual rainfall is 40 inches a year.
Never enough camping!!
jonnys_walkers is offline   Reply With Quote
Old 12-25-2014, 03:47 PM   #13
Changing your fuel source for heat is not going to change your condensation issue. Both this D5 and your propane furnace produce heat by a heat exchanger, same technology just different fuel. The D5 is more efficient only because there is more energy (BTU's) per gallon in diesel than propane... About 52% more in fact.
-Sean
2011 Sunseeker 3170DS - 30,000 miles explored
funfinder5 is offline   Reply With Quote
Old 12-25-2014, 04:23 PM   #14
caper's Avatar
When boondocking you could try using damp rid or some other type dry dehumidifying compound.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 12-26-2014, 09:39 AM   #15
Denver, CO
garbonz's Avatar
-Sean
Dat's the truth. Nuff said. Maybe you have a source of moisture like a leak that is adding water to the inside. PLUS the R-values are very low and this the walls and windows are cold. Dew point is a function of temperature of the surface.
2017 Fuse 23T
Old 12-26-2014, 09:50 AM   #16
jk510's Avatar
As you said you live in a very damp, humid location so there is already a lot of moisture in the air. When you heat it up it's still damp but now warmer. When that warm, humid air contacts a still cold surface like the windows you're going to get condensation. The same principle as a cold glass of ice tea on a warm summer's day.
Joel K
Southeast AZ
2013 Coachman Mirada 29DSSE
jk510 is offline   Reply With Quote
Old 12-26-2014, 10:20 AM   #17
Denver, CO
garbonz's Avatar
Sort of.
Condensation is a function of the temperature of the surface and the amount of moisture in the air, regardless of the air temperature. The amount of moisture in air in absolute terms is expressed as grains of moisture, is independent of temperature. Condensation occurs when the temperature drops below the dew point at the surface and the air at the surface cannot hold the moisture any longer and water droplets form. In an RV, the cold surface caused by the low R values, make condensation worse than in a typical house. AND in a house, the lower R value of windows cause the condensation to occur there sooner than walls, something most of us observed.
Lot of more complexity to this subject, but this is the basics.
In order for condensation to form there has to be some moisture in the air, and a cold surface (relative to the air) for it to form on.
2017 Fuse 23T
Old 12-26-2014, 11:33 AM   #18
Ret E-9 Anchor-clanker
donanddona's Avatar
I find most moisture is found when we close the windows due to cooler temps. This moisture collects on window ledging and I need to paper towel daily. Untill, I got a whole house dehumidifier, it does a fantastic job. It has a led read on humidity levels and will auto start and auto stop at your desired setting. During rainy days I run it in constant mode. I dump the collection tank daily.
donanddona is offline   Reply With Quote
Old 12-26-2014, 11:59 AM   #19
Witch Doctor's Avatar
Garbonz, gave a pretty good answer, but most will tell you it pour circulation and cooking and showering and washing dishes and most of all bad insulation.
What is condensation?
Condensation is the process by which water vapor becomes a liquid. The air in our atmosphere contains anywhere from 0 to 4 % water vapor. This water vapor will remain in the air until either 1) so much water vapor is added to the air that it becomes saturated and can no longer hold the water vapor, or 2) the temperature of the air drops low enough that the air can no longer hold the water vapor. In either case the water vapor turns into liquid and forms on a surface as condensation.
What does it indicate?
When you see condensation forming on your windows it is a warning that there is too much water vapor in the air of your home or that there is insufficient air circulation next to the windows on which the condensation is occurring.
What causes condensation?
Condensation is caused by the air temperature becoming too low to hold the water vapor that is in it. The factors involved in condensation are as follows:
1. The amount of water vapor in the air of the home (measured in relative humidity).
2. The circulation of the air within the home.
3. The air temperature. Both in the home and outside.
The air in a room contains water vapor. The amount of water vapor in the air varies and is commonly expressed in terms of relative humidity. Relative humidity is the measure of the amount of water vapor actually in the air compared to the maximum amount of water vapor the air can hold at that particular temperature and pressure. The fundamental principle concerning air and relative humidity is: the warmer the air temperature, the greater its capacity for holding water vapor. When warm air in a room comes in contact with a cold surface the air around that surface begins to cool. As it cools its ability to hold water vapor decreases. Eventually, it reaches a temperature at which it can no longer hold the water vapor. This is sometimes referred to as the dew point. When the air reaches this point the water vapor begins to condensate, forming as tiny droplets of water on the cooler surface. Often times the glass in your windows is the coolest visible surface and this is why you may see condensation develop there first.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 12-28-2014, 05:29 PM   #20
A liter of water per person per day, between perspiration and exhalation. Stick 3 in a camper overnight (8 hours) and you have a full liter on the walls/windows/ceiling if it is sealed up and the A/C isn't running.
If the A/C is off, always keep a window and the bathroom vent cracked open to create a convective airflow to get the moisture out. I've camped in 8 F with a window and vent open slightly.
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
diesel, propane
