Old 12-24-2014, 05:10 PM   #1
jonnys_walkers's Avatar
Propane versus Diesel
We seem to have the same issue as others with off-season camping and heating with propane.
We find that the propane heat is very wet, so the windows and walls sweat.
Since the toy-hauler has a fuel cell I am considering installing two of the D5's to replace the propane furnace:
http://www.espar.com/fileadmin/data/...Spec_sheet.pdf
Has anyone else installed one of these or given any consideration to install one or two?
John
Never enough camping!!
jonnys_walkers is offline   Reply With Quote
Old 12-24-2014, 05:38 PM   #2
RPAspey's Avatar
Unless you have a radiant propane heater, an RV propane furnace is a sealed unit. Outside air into combustion chamber then exhausted out. Thats why there are two openings in the wall plate on the outside of the RV. No combustion air is exhausted into the rv. The windows and walls sweat due to moisture that is exhaled and from cooking condensing on cold surfaces.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 12-24-2014, 05:51 PM   #3
Infractee
X2
the furnace is a heat exchanger, nothing from burning propane (should) enter the RV. The wet is from you.
RhoZeta is offline   Reply With Quote
Old 12-24-2014, 05:54 PM   #4
Denver, CO
garbonz's Avatar
Better to just get used to the condensation, which is due to the low Rvalues of the windows and walls in RV's Try not to breathe to much or make food.
2017 Fuse 23T
Old 12-24-2014, 06:25 PM   #5
VinceU's Avatar
Very important to vent outside during cooking or showering, prevent mold!
Old 12-24-2014, 07:02 PM   #6
RPAspey's Avatar
We crack open the headboard window when heading to bed. That helps a bunch with condensation. I also sleep better with the fresh air too.
Old 12-24-2014, 08:36 PM   #7
caper's Avatar
Try using a dehumidifier, you will find the unit will feel warmer and have little to no moisture inside the unit.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 12-24-2014, 08:48 PM   #8
mark0224's Avatar
X2 on the dehumidifier, last March I decided to get an early start on doing some Mods and turned the dehumidifier on with the furnace, so I could work in comfort. When I was done I turned the furnace off but left the dehumidifier on for a couple of hours then went out and retrieved it so it wouldn't freeze. Never had any wall sweats or condensation on the windows. One day I even went out and shampooed the carpets, left the furnace and dehumidifier on till carpet was dry still no condensation.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 12-25-2014, 11:17 AM   #9
I can run the propane heater parked in the yard uninhabited and the windows and walls are covered with moisture, not from cooking or people breathing.
When boondocking dehumidifiers are not an option.
Thanks for the input.
Old 12-25-2014, 03:06 PM   #10
VinceU's Avatar
I might seriously be thinking about having some expert check air quality in your unit, it just ain't right with all that moisture. CO and CO2 gas may present w/the moisture.
diesel, propane
