Old 10-14-2011, 05:31 PM   #1
propane woes
I just came back from a camping trip and when I get back it's time to refill the propane tank. I took it to a local Southern States Co-Op where they filled it up. When I get home I'm checking everything out and no gas to the Stove or range, hot water tank, and furnace. Not sure about the freg.
I've looked over the propane valve and it is open. Any ideas on what is going on?
After I posted this I went to the Forum and found that if the LP dector is off the gas wouldn't work. Should have looked first because it was off and when I turned it on, everything works.....Feel like a dork but at least not having to take it to a dealer.
Camping 2012 (5)
Flyboy740 is offline   Reply With Quote
Old 10-14-2011, 06:07 PM   #2
close the valves, wait five minutes and opem slowly. These new valves will shut down believing there is a leak if opened too fast.
