Old 05-11-2014, 05:36 AM   #11
Pirates55's Avatar
Originally Posted by RickV View Post
That looks like a grill I have. Is it from Sam's? I bought it for the old 5ver new 5ver came with one. Did you have to remove the regulator to use your on board propane?
Yes. I bought it from SAM's
Pirates55 is offline   Reply With Quote
Old 05-11-2014, 05:38 AM   #12
Pirates55's Avatar
Quick connect hose question
I found this online and it appears that it would work. The whole high pressure and low pressure stuff confuses me. Any insight from you guys on that.
Name:	ImageUploadedByForest River Forums1399804700.753034.jpg
Old 05-11-2014, 07:45 AM   #13
bmg
I think w/o the regulator it would be considered high pressure. Since you have a reg on your main RV tanks, you have to remove the reg on the grill, since it won't work with 2 regs in the line. The hose you show should work fine. CW and Wally carry them too along with many other stores. The fittings you should get at a plumbing supply.
bmg is offline   Reply With Quote
Old 05-11-2014, 09:36 AM   #14
Cover Dog's Avatar
Send a message via ICQ to Cover Dog
I have just done what you want with the exact same grill from Sam's Club. You need to purchse a Camco 10' hose/or shorter #57282 look on amazon/ebay. Then purchase this fitting LP Quick Connect Fitting 1 4" Male NPT x Male Quick Connect Camco 59903 | eBay
Unscrew the fitting with the pressure valve off the grill and take it to a outdoor grill company that can make hoses. Have them cut off the pressure valve and replace with the quick disconnect fitting you bought. Then screw back onto the grill the short end of hose with the new quick release fitting (minus the pressure valve) and then plug that into the longer hose you have installed on the camper at the quick disconnect site. Your done...
Bill, Maura & Rosie the rescued Boston Terrier
2016 Winnegbago Adventurer 38Q....26K Chassis
...traded in 2015 Wildcat 282RKX
2014 CR-V EX-L w/Nav & Blue Ox & Ready Brute Elite
NRA Endowment Life Member, FMCA #455593, WIT #170814 & Mid-Ohio Winnies
Cover Dog is offline   Reply With Quote
Old 05-11-2014, 10:08 AM   #15
AquaMan's Avatar
Attachment 52138
This where I bought all my fittings and hoses for my grill conversion. I changed all my fittings to theirs as they work smoother and some manufacturer fittings are not compatible with others, even though they say they should be. I also have a high pressure line off one of the tanks for a firepit. The high pressure lines are required for high btu devices that have a different WC rating than the on board regulator.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 05-11-2014, 10:17 AM   #16
R&J Silverback's Avatar
quick disconect
I have the same BBQ you can buy the what you need at CW just take mone off screw on the other cost was like $35 works great.
Ron & Jan and black dog(Bella)
2011 Ram 3500 crew cab 4x4, 6sp manual,342's 8ft.bed
2014 CC Silverback 29ik
R&J Silverback is offline   Reply With Quote
