Old 08-08-2014, 06:40 PM   #1
Quick disconnect
Can I use the quick disconnect to add another LP tank to the system?
Thanks.
Tim Myers
2013 Ford F-450
2015 Sabre 34 REQS-6
2018 XLR Boost 27QRB
dustym is offline   Reply With Quote
Old 08-08-2014, 07:29 PM   #2
davidjb's Avatar
Seeing as the outlet comes out of a line that is hooked up to your regulator I dont think it would be a good idea to try that, I think you will ruin your regulator back feeding it. or burn you trailer down.
davidjb is offline   Reply With Quote
Old 08-09-2014, 06:40 AM   #3
Thanks for the info. So what is it good for? Cant run a small Bar B Que from it, and am not going to lug a big one around.
Tim Myers
2013 Ford F-450
Old 08-09-2014, 07:03 AM   #4
dan-nickie's Avatar
I believe many use it to run a small BBQ.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 08-09-2014, 07:13 AM   #5
Camper Less Camping
Cajun Po-Boy's Avatar
Most modify their small or large gas grills by removing the BBQ regulator so you can connect to the camper line...no more hauling mini or 20lb propane tanks
Sent via Cajun Po-Boy's Tech Gear
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 08-09-2014, 09:19 AM   #6
I just want to have extra capacity. I have extra bottles, so if I run out, I can just hook one of the others up. Our property is 18 miles from town, and have some other bottles that I would like to use up. They are too big to fit in the compartments on this new one and wiyth the last one.
Tim Myers
2013 Ford F-450
Old 08-09-2014, 10:03 AM   #7
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Tim, you sure can. This is what long term campers do. You can get the parts needed at propane suppliers when you explain to them what you're planing to do.
Edit: Be careful, since you're coming in after the regulator you must also install one between your tanks and the quick disconnect.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 08-09-2014, 10:12 AM   #8
On second thought, why not just extend the original hose that connects to your existing tank and avoid all the trouble.
Old 08-09-2014, 12:32 PM   #9
Thats what Ill do then, just didnt know what parts are needed. I just thought with this new one, that it had the solution I was looking for.
Thanks everyone for the info.
Tim Myers
2013 Ford F-450
Old 08-11-2014, 10:04 AM   #10
Old Enough to Know Better
gasman6674's Avatar
The quick disconnect is after the regulator, so it is low pressure (11"wc/6.35oz) You could back feed your system from an external tank AS LONG AS THE EXTERNAL TANK HAS A LOW PRESSURE REGULATOR. It will not hurt the existing RV regulator. I would recommend you shut your RV tanks off and just pull from external tank leaving the original as a reserve. Please note DO NOT hook up a tank with out a regulator and DO NOT use a forklift/tow motor tank
On the BBQ question as long as the unit is set up for low pressure you can plug it right into your quick disconnect by removing its regulator and getting the correct mating connector. CW has a low pressure unit and I found a nice unit at Lowes that I am waiting on "end of season" clearance. If the grill uses disposable bottles you will need to get a kit if available from OEM or modify it yourself.
Hope this helps
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
