Old 09-26-2016, 12:53 PM   #11
Originally Posted by kfd82 View Post
If running off the already regulated RV propane you shouldn't have a regulator on the grill also.
You are double regulating and killing the flow.
X2. You have to remove the regulator from any appliances you are going to run off of you're already regulated supply line.
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags.
2011 28RKS Wildcat. Yamaha 3000iseb Generator.
2013 22 nights.2014 57 nights.2015 116 nights +14300KM
2016. 96 nights
Filterman is offline   Reply With Quote
Old 09-26-2016, 01:14 PM   #12
rsdata's Avatar
I don't know if this will help you but doc73 listed all the parts to covert a high pressure Coleman stove to use the low pressure gas line from the camper and getting rid of the regulator on the stove, and still allowing you to use it stock if ever necessary... provided part numbers and everything... great write-up
Switched to Quick Connects for Coleman Roadtrip Grill
2014 Shamrock 183
2014 RAM 1500 SLT Crew Cab HEMI 3.21 8 Spd 4X4
Old 09-26-2016, 02:41 PM   #13
I just converted my Weber 2200 to a quick connect to the rear of my fiver. I used a similar video as above. Purchased a small adapter and a 10' hose and had the whole conversion done in about 20 minutes.
Jeff from Burlington Ont is offline   Reply With Quote
Old 09-26-2016, 02:54 PM   #14
sfsgm's Avatar
Agreed.
2016 Nike Take Down Wrestling Shoes
38 ft square Dollamaur High School Wrestling Mat
sfsgm is offline   Reply With Quote
Old 09-28-2016, 10:06 AM   #15
Originally Posted by ccsvolsfan View Post
X2 on Olympian grill .
X3
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 09-28-2016, 10:11 AM   #16
Should I install the quick connect on the camper or let the company I buy propane from install the connection. I have a 100 gallon LP tank I want to hook up too, that way I don't have to winterize the camper. We go somewhere each month
