Old 09-25-2016, 02:19 PM   #1
Cliff & Gail
Quick Disconnect LP Connection
Took my 5'ver to a local dealer to install a quick disconnect for my new grill. Sure looked good 'tll I tried to lite it up . . . NO CIGAR!!
I put a propane bottle on the new regulator and it heated up to 500 deg! Put the hose back on it and nothing. I called the dealer and talked to the tech. He said he check'd it and there was gas flow.
We decided: the RV regulator cuts the flow down to 10 ipw (inches of water-is that the volume of measure?) and the grill regulator keeps the LP flow low also.
Was the tech blowin' smoke or what? Somebody out there has to be feedin' their grill off the RV propane system. What's up??
Cliff Golden
'05 Wildcat 27RK
'00 Ford 7.3 CI Super Duty
Cliff & Gail
Odessa, TX
'00 F-250 TD
'06 Wildcat 28RK
cliffgolden is offline   Reply With Quote
Old 09-25-2016, 02:38 PM   #2
kfd82's Avatar
If running off the already regulated RV propane you shouldn't have a regulator on the grill also.
You are double regulating and killing the flow.
kfd82 is offline   Reply With Quote
Old 09-25-2016, 04:27 PM   #3
Blog: RVroadtripper.com
hbillsmith's Avatar
Convert BBQ to use onboard low pressure propane
Check out this youtube. There are others like it (including one I did) but I think this guy did the best easiest explanation.
Weber Q1200 High Pressure to Low Pressure RV Conversion
Maxxis 16" E; Ride Rite AirBags w/AirLift 1 wireless compr; Adv.Folding 4 Cover
Andersen Ultimate II Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball
LCI Ground Control 3.0 4pt + 2pt Elec.Rear stabilizers; 3 Slidecovers; 10ft. Portabote
6000# Dexters; mor/Ryde CRE3000 w/HD Wetbolts; King Dish Tailgater; 5hp Outboard
Dual A/C; Furrion 48 Rear Camera; Champion 3100 Inverter w/Extended Run
hbillsmith is offline   Reply With Quote
Old 09-25-2016, 04:40 PM   #4
Moderators' Assistant
bikendan's Avatar
Cliff Golden
'05 Wildcat 27RK
It would help if you posted what grill you're talking about.
High pressure grills won't run off the RV pigtail propane hose because it's low pressure.
Most have to remove the grill's regulator and then adapt it to use the quick disconnect.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 09-25-2016, 04:49 PM   #5
Cliff & Gail
Quick Disconnect LP Fitting
Sorry 'bought that. It's a Char Broil (low pressure) 'Grill 2 Go'. I kinda figgured putting a diaphragm control on a low pressure 'in' line was shooting myself in the foot. But it shuts the flow down completely.
Workin' on takin the thing apart now to see if I can find the parts. Thanks all! CG
Cliff & Gail
Odessa, TX
'00 F-250 TD
'06 Wildcat 28RK
Old 09-25-2016, 05:17 PM   #6
bikendan's Avatar
Who told you that it's a low pressure grill?
That's a typical high pressure portable grill.
It normally uses the 2lb high pressure propane tanks, meaning it's a high pressure grill.
Old 09-25-2016, 05:47 PM   #7
DDC
DDC's Avatar
You need one of these, Camco 57274 Control Valve with Quick Connect, amazon has it. You can't regulate twice, your quick disconnect is already giving you low pressure gas.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 09-25-2016, 08:45 PM   #8
10 inches of water column is a measure of pressure, not volume. propane appliances expect the propane pressure to be 10 - 11 inches of water. just fyi, 10 inches of water is about .36 psi.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 09-25-2016, 08:51 PM   #9
mikkeeh's Avatar
The problem with alot of the high pressure grills is that the gas regulator, and the flame control , are one and the same. If you remove the regulator, you lose your flame control.
I bought a Olympian 5500, and its awesome. Not cheap, but one of the niceset grills Ive ever used.
mikkeeh is offline   Reply With Quote
Old 09-26-2016, 01:29 PM   #10
ccsvolsfan's Avatar
X2 on Olympian grill .
ccsvolsfan is offline   Reply With Quote
