Old 04-26-2014, 09:55 AM   #31
My first thought on this thread wasn't running down the road or refueling, but having an accident. Any thoughts on that?
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 04-26-2014, 10:01 AM   #32
The frig being on wouldn't have much to do if you're involved in an accident, the propane lines are still there and the chances of the frig burner being on at the time and a flame present would be very remote. The stove and furnace are there also, but no flame present. Just because the frig is on propane doesn't mean there is a constant flame, quite the contrary. It might come on maybe one time an hour if that and then for only a few minutes.
Old 04-26-2014, 04:06 PM   #33
I'm wasn't thinking of the fridge, per se. I'm thinking the flimsy copper gas line tears off, gas spews out, a spark occurs when something metal scrapes on the asphalt, the gas bottle valve is open and voila', gas fed fire.
Old 04-26-2014, 04:14 PM   #34
Do you work in the (Hollywood Movie Field)? Youroo!!
Old 04-26-2014, 04:49 PM   #35
MtnGuy's Avatar
There is supposed to be an safety check valve on modern RV propane systems to prevent that type of problem. The safety check valve should operate if there is no back pressure on the system.......that is if everything is working properly.
Old 04-26-2014, 04:49 PM   #36
We just saw a FedEx truck hit a bus and everything went up in flames. Not Hollywood.
Old 04-26-2014, 05:01 PM   #37
dretired's Avatar
Hmmm...a friend of mine forgot to secure his propane tanks in Florida...while 20 miles from home (in Michigan) on I-94 ..a car pulled along side and the people were screaming & pointing at his tanks dragging by the hoses ..." SCRAPING THE ASPHALT !! SPARKS FLYING'!!....OMG !!!..no explosion that day...WHEW !!...
2014 Crusader 325 TE....2012.. F 250.. Supercab XLT, 4x2 , diesel....days camped 2011 ... 28.... days camped 2012...115 ... days camped 2013...155...2014...171 and counting
dretired is offline   Reply With Quote
Old 04-26-2014, 05:28 PM   #38
Wouldn't make any difference whether the frig was on or off. If something happens and a rock knocks the shutoff valve off the tank you have a bigger problem. I think you are being a little paranoid.
Old 04-26-2014, 11:13 PM   #39
Check your tank. There's a guard around the valve, and most people have covers on top of that.
I'm not paranoid; I never even said I wouldn't/couldn't run with the fridge on. I simply asked for comments. Sounds like most people don't have a problem with doing this.
Old 04-26-2014, 11:25 PM   #40
I saw that too, sad story but I would think both vehicles probably ran on diesel? No fridge?
2016 Siverback 33IK
dalford is online now   Reply With Quote
refrigerator, travel
