Old 05-10-2013, 07:31 AM   #1
Regulator
I have a auto change over regulator off my old camper. It's the one with the site glass that turns red and green. It hasn't been used in 2 years. Well I put it on my new camper with fresh bottles and I can't get it to turn green. Think it has froze up inside. Anyway to free it up or just get another?
labman1014 is offline   Reply With Quote
Old 05-10-2013, 10:44 AM   #2
Fire Instructor's Avatar
When mine failed like that, I just replaced it. Inexpensive enough.....
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 05-10-2013, 11:35 AM   #3
Herk7769's Avatar
Did you install the old one yourself?
Does it show "Green" until you open an appliance?
Causes of "no gas - RED" indications
1) Joint Leaks - Were joints sealed with gas safe (yellow) Teflon tape?
2) Leak shutoff valves tripped - If the tanks are opened too fast, the safety valve in the pigtail can trip shutting off flow. (Open very slowly after at least a 2 minute "rest" to reset.
3) Empty tanks
4) Bad regulator - stuck check valves in inlets to regulator body.
HAM CALLSIGN - KC3FFW
Old 05-10-2013, 01:30 PM   #4
Sight glass is red and there r no leaks, checked with soap and water. Freshly filled tanks.
I ended up getting another one and I'm good to go. Heading out in a few hrs and needed to get the fridge going.
Tks guys!!
