Old 05-21-2015, 02:47 PM   #1
2014 Berkshire 360QL
Regulator on Weber Grill
We have a 2014 Berkshire with a propane line and quick connect set up on the passenger side in a compartment. The intent is to connect a propane hose to this connection for a propane grill. As I understand it, the rig has a propane regulator as well as the Weber Grill having a propane regulator which means the Weber Grill will not receive enough propane to work. I also understand that you must modify the Weber Grill. What does one have to do to modify the Weber Grill? Is it possible to remove the regulator and use some kind of adaptor to connect the hose from the RV to the grill?
Thanks in advance for your help.
Richard D is offline   Reply With Quote
Old 05-26-2015, 05:18 PM   #2
Del78's Avatar
Hi I am in similar situation with a broil king porta-chef 120, as long as the regulator is threaded on, should not be too difficult to modify.. Take your grill to our local hardware and explain what your doing, they should have the necessary quick connect fittings and propane hose required. Hope this helps a little!
Del78 is offline   Reply With Quote
Old 05-26-2015, 05:41 PM   #3
Del78's Avatar
If the regulator on weber is welded on and not removeable, the other option is to install a tee right before your tt's regulator and run a propane hose direct to your weber, this would also not void any warranty on your weber.
Old 05-26-2015, 05:59 PM   #4
dan-nickie's Avatar
Converting WeberQ for Berkshire Quick Connect
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 05-26-2015, 06:39 PM   #5
mud yapster's Avatar
I'd think it wouldn't hurt anything to have 2 regulators in line together. They are made to reduce the tank pressure so one regulator will be closed to give you the right pressure and the other one will be opened to maintain the right pressure so should still work fine Hooking two in series with each other. Hope that makes sense to you.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 05-26-2015, 11:00 PM   #6
Blog: RVroadtripper.com
hbillsmith's Avatar
See dan-nickie response. Thats what I did. Search youtube for "convert weber Q1200" also.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 05-26-2015, 11:11 PM   #7
Del78's Avatar
Dan that's a great demonstration, feel free to advise me on hooking up a broil king porta-chef 120 to a 2011 wildwood xlite 26bf using either low pressure line or bypass fittings required at main propane supply.
