Old 08-19-2015, 01:02 PM   #1
RVcool cooling unit
I recently bought a replacement cooling unit from rvcool. I assembled everything and used the welded bracket to mount my propane to however the flame does not line up with the hole in the flu. Anybody run into this and what should I do. RVcool says if I try to bend the bracket it will void the warranty.......
Nick Norwil is offline   Reply With Quote
Old 08-25-2015, 05:38 AM   #2
Crockett's Avatar
this core was probably bent somewhere in production. how do they tell you to remedy this situation?? did you send them pictures?
Crockett is offline   Reply With Quote
cooling
