07-12-2016, 10:18 PM
Small Coleman Tanks
Did not see any posts about this so thought I would ask. Is there any issue storing these inside the RV (inside the outside storage)?
2016 Coachmen Freedom Express Liberty Edition 292BHDS
07-13-2016, 09:37 AM
We live where it is very hot and have always kept them in the outside (basement) storage. Years and years with no problem. But I did just read a thread of a fellow that had his canisters leak. That's the first time I have heard of that happening to anybody. So I would not store them inside the rv like he did but an outside vented cubby should be good.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
07-13-2016, 09:55 AM
Store mine in the basement.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "14"
07-13-2016, 09:58 AM
Alleged curmudgeon
Case in point. My nephew had a Coleman cannister leak while we were camping together last month. He discovered it when he disconnected it one day to store the grill. He heard it leaking and showed it to me. We could not get it to stop, so we reconnected it to his grill and he left the grill out for the remainder of the week. The night before breaking camp, when he was done with his grill, we had no choice but to disconnect it and just sit it aside (outdoors/ventilated) until it ran out. I don't know how common that is, but I would hate to have it occur in a closed compartment.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34); 2018 (39); 2019 (30); 2020 (16); 2021 (14); 2022 to date (12)
07-13-2016, 10:03 AM
When I used them I stored them behind the trailer tanks, just enough room for them to ride upright.
07-14-2016, 10:07 AM
Thanks everyone for your responses.
07-14-2016, 05:59 PM
Funny story about this. We bought a new (to us) tt this spring and promptly loaded it and went camping for a week. About the 3rd night the propane alarm goes off. After checking everything I could think of I aired out the camper turned the propane tanks off and figured I would continue looking for a leak in the am. So the next morning I turned the tanks back on and no alarm. About 4 hrs later the alarm goes off again. So I mix up some soap solution and start looking for a leak. I take everything apart to check for a leak at the fridge, stove, furnace, and water heater. But no luck. So I decide to get my adjustable wrench out of my pass through and make sure the connections are tight. When I open the door to the pass through, I smell propane! Turns out a small propane cyl in the compartment was leaking.
07-14-2016, 07:15 PM
[QUOTE=RCW;1258975When I open the door to the pass through, I smell propane! Turns out a small propane cyl in the compartment was leaking/QUOTE]
Just curious, was it a used canister or a never been opened one?
07-14-2016, 08:02 PM
[QUOTE=NMWildcat;1259033]
Originally Posted by RCW;1258975When I open the door to the pass through, I smell propane! Turns out a small propane cyl in the compartment was leaking/QUOTE
Yes, it was a used canister.
07-14-2016, 09:15 PM
[QUOTE=RCW;1259065]
Ah. Thanks. I've never seen a new one leak myself. The used one I can understand. We try and use them up and if they have just a little left we usually just chuck 'em.
07-19-2016, 11:34 AM
That has happened. When it does, take a small needle nose pliers and pull up the relief valve or the one in the inside of the thread.
07-19-2016, 11:43 AM
The valves are basicly a schrader( tire) valves. Sometimes you can just pop the valve stem with a toothpick and they will seal. A drop or two of water, WD40 or the like will tell you if you took care of it. I used to refil these during the years where I ice fished regularly. Never tried pulling up on the valve stem...that may work too!
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
