Old 07-18-2015, 02:20 AM   #1
Stainless Steel Braided Hose
One side of my tanks pigtail hose is leaking and if im going to replace them i want to get a Braided one, where is the best place to order one, or are there any places in town that might have them or be able to make them?
Deeks is offline   Reply With Quote
Old 07-20-2015, 01:22 AM   #2
Crockett's Avatar
you could get one of these qcc fittings. they have a 1/4" male npt thread. then maybe get a hose made or find one with 1/4" npt male on one end and 1/4" npt female on the other. i dont know of any already made. make sure the rubber is lp gas compatible. the reg will take the 1/4" npt male end. let us know how it works out...
Crockett is offline   Reply With Quote
Old 07-20-2015, 01:39 AM   #3
Just a member
kandl's Avatar
Originally Posted by Deeks View Post
One side of my tanks pigtail hose is leaking and if im going to replace them i want to get a Braided one...
Curious. What's the benefit of braided SS in a RV application over an off the shelf rubber replacement?
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 07-20-2015, 02:03 AM   #4
Crockett's Avatar
probably just appearance. op might be frustrated with the life of these hoses. I know i am. i carried the hose with the solid copper crimp band in the store for a while but these were the worst. now i sell the other style with the thin brass crimp because they hold up better.
Old 07-20-2015, 04:11 AM   #5
Just a member
kandl's Avatar
Bling is cool but how does the steel braiding influence the life of a LP hose? Noticed Amazon carries an assortment of these braided LP hoses and they look pretty cool but, again, what's the benefit?
Old 07-20-2015, 04:59 AM   #6
Big Rig's Avatar
Maybe to stop the rodents and squirrels from eating the hose. I recently had to replace the line on my webber at home after the chipmunks ate into it. They recommended the braided hose for this problem.
Big Rig is offline   Reply With Quote
Old 07-20-2015, 11:07 AM   #7
Old Enough to Know Better
gasman6674's Avatar
The only ss braided hose I am aware of is the Parker hose it has a stainless steel internal braid over a rubber inner tube covered by a rubber and fabric outer cover. its available in
3/16", 5/16", 13/32" and 1/2" id commonly used on LP gas motor fuel (forklift and auto gas) applications. You have to field install the 2 piece reusable couplings and to my best knowledge they don't make a 1/4" inverted flare fitting for the regulator end so you would have to adapt. Very abrasion resistant but a determined critter can chew it given time.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 07-20-2015, 12:41 PM   #8
Crockett's Avatar
if you pull the brass fitting on the reg..your at 1/4"npt
Old 07-20-2015, 02:34 PM   #9
Crockett's Avatar
heres a hose, 1/4" fpt each end, needs a 1/4" mpt nipple to work. 24.95
Old 07-20-2015, 03:20 PM   #10
I have been down this road before. I believe the best place to go is a full service PROPANE STORE that sells and services propane hook ups which is NOT necessarily an RV Store. They will have the right stuff for EXACT replacement and a safe replacement. If you use the wrong hoses you potentially will have a BOMB that may go off someday.... Just saying.....
dually75019 is offline   Reply With Quote
