Old 05-26-2019, 09:19 PM   #1
Stove burners too hot
Is there any way to make the low setting on the stove top lower? It's too high to simmer, and food burns easily.
Eldereaglewatcher is offline   Reply With Quote
Old 05-26-2019, 09:26 PM   #2
bob213's Avatar
I tried and ended up buying a diffuser that sits on top of the burner.
https://www.amazon.com/Simmer-Flame-...%2C703&sr=8-12
You can avoid reality, but you cannot avoid the consequences of avoiding reality Ayn Rand
bob213 is offline   Reply With Quote
Old 05-26-2019, 09:42 PM   #3
clarkbre's Avatar
Raise the pan/pot twice as high to make a lower heat source. What stove/trailer are we talking about. I find the 3 burner Suburban propane stove doesn't boil big pots of water fast enough...
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is online now   Reply With Quote
Old 05-26-2019, 09:55 PM   #4
Talking about a 2017 Rockford Mini Lite. I'll look for a diffuser as suggested. Thanks.
Old 05-26-2019, 10:09 PM   #5
You can use a large tin can lid.
ppine is offline   Reply With Quote
Old 05-27-2019, 12:17 PM   #6
Adjustment
Propane stove? You can pull the knobs off and use a thin flat-blade screwdriver to adjust the minimum level for each burner. Be careful. Just change it a little at a time. If you get it too low, a gust of wind when someone opens the door could blow out the flame. (Probably why they set the bottom of the range so high.)
Larry
Larry-NC is online now   Reply With Quote
Old 05-27-2019, 12:32 PM   #7
2012 Solera
[QUOTE=bob213;2104625]I tried and ended up buying a diffuser that sits on top of the burner.]
X2. We use the cast iron version:
https://www.amazon.com/Diffuser-Plat...s%2C204&sr=8-4
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 05-27-2019, 12:55 PM   #8
I had the same problem, so I bought a 2-burner electric cookplate. Small and large burners, able to set pretty low, to cook things like chili and stews without scorching. PLUS: using the electricity instead of your propane. The unit is small enough to shove under the kitchen sink [a shelf is there], and doesn't take up much counter space. If I am using it alone, I just put it on top of the stove-glass.
smgelsie is offline   Reply With Quote
Old 05-27-2019, 01:46 PM   #9
For the rare occasion I'm on shore or generator power I use one of those Induction units (as seen on TV). Boils water quicker than even propane burners and it can be throttled down to just make a bubble in a pot of chili every once in a while.
Been meaning to get a diffuser but so far I've just resorted to a lot of stirring.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
Old 05-27-2019, 02:16 PM   #10
Save yourself the trouble and buy a Caso 1800w induction plate, 12 temp settings no flame no gas shuts off in 2 seconds, I can saute onions and garlic and never splatter a drop, cast iron pan, 139 bucks on Amazon German made, solved our problems.
Flapjackdenny is offline   Reply With Quote
burner
