Old 04-25-2016, 09:06 AM   #21
Old Enough to Know Better
gasman6674's Avatar
Originally Posted by JZales View Post
No. I don't smell or hear anything. I took off the bottom stove shield and sprayed connections and didn't see anything. However I am a little concerned that is currently the only stop valve.
Any idea how involved it is to replace the tank valve?
John
Depending on the valve manufacturer you might be able to rebuild the existing valve. But for that to be done the tank will need to be empty. Since its such a minor issue and your stove valves are not leaking, use the gas out of the tank then either have the dealer repair it or your local LP Gas Dealer
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 04-25-2016, 09:17 AM   #22
Phat Phrog Stunt Crew
elind's Avatar
Is there room to put a second valve just after the first valve? That would save you from empting the tank and replacing the first valve.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 04-25-2016, 09:30 AM   #23
Makes Total sense that you have a "SLOW" leak that will build "Full Pressure" over a period of time! You need to have the Valve replaced and "Properly Checked" for leaks! This is a Very important safety issue ! Youroo!!
youroo is online now   Reply With Quote
Old 04-25-2016, 09:34 AM   #24
I would still open the valve completely and then close it tightly. I think you just don't have the valve closed completely.
light, propane, tank
