Originally Posted by Skyliner
2009 FR Wildcat 27RL
I'm losing propane and can't figure out from where.
Replaced all flexible hoses and two regulators-there is a 30 PSI regulator on driver's side tank and a 2 stage regulator on pax side tank area.
Sprayed soapy solution on all hard fittings-no leaks.
Sprayed soap solution on flared connection to stove-no leak
Sprayed soap solution on connection to heater-no leak.
Sprayed soap solution on connection to water heater-no leak.
There is no odor in camper and propane gas detector has never gone off.
I'm not sure where to look next. Can the gas solenoid valves in the hot water heater or furnace leak?
It is taking about 3-4 days to lose 30 lbs of propane.
Thansks,
Drew
That's a lot . I would think you would smell it at that rate. Check the regulators. BBQ fitting if you have one. Then check all the piping, leaks are not always at the brass fitting . you may want to get a gas sniffer if the soap and water doesn't show up anything . You would smell if the gas valves on the h/w/h , furnace , refrigerator were leaking that much . check the tanks themselves . have you done a leak down test ?
