Old 07-12-2016, 12:04 PM   #1
Suburban Heater not heating - in Alaska
We are in Alaska in our Flagstaff 8528 IKWS 5'er and our heater has stopped working. (Not water heater)
Worked fine til this morning and now it runs (fan) briefly then shuts down.
Propane is confirmed full.
Fuses are all good.
Based on reading here I have removed a couple covers trying to locate a reset switch but cannot find it.....have not been able to see much of the unit yet and wanted to hear from you guys before I continue.
Where is the switch (inboard, outboard, forward, aft?) and how do I get to it?
Thanks in advance!
Wdw0528 :-)
A contributing factor - although we travel slow on the roads here I was caught off guard on one yesterday and hit a pot hole a little faster than I wanted.
Darrell & Kathy
2013 Flagstaff 8528IKWS 5er
2013 Ford F250 6.7 Diesel
B&W Companion Slider
wdw0528 is offline   Reply With Quote
Old 07-12-2016, 10:15 PM   #2
Do you mean the furnace? Are you plugged in to shorepower? Are you running off of the battery?
Kuba is offline   Reply With Quote
Old 07-12-2016, 10:43 PM   #3
Yes, furnace.....sorry for the confusion.
I am currently running via generator (no electric in current location) but have tried on just battery and Denny with same results. Fan runs briefly (no heat) or sound of ignition and then shuts down.
Darrell & Kathy
Old 07-12-2016, 10:48 PM   #4
Genny, not Denny :-)
Darrell & Kathy
Old 07-12-2016, 11:34 PM   #5
Do you hear clicking coming from the furnace once the fan goes on? Does your stove work?
Old 07-12-2016, 11:36 PM   #6
Stove works fine.
Used to hear a clicking from furnace when igniting but no longer.
Darrell & Kathy
Old 07-13-2016, 05:27 AM   #7
ilmor's Avatar
Fuses are all good.
Thanks in advance!
Wdw0528 :-)
Somewhere in your camper you have a breaker box / fuse box which should contain all that stuff, the first thing to check for is a blown fuse or popped circuit breaker.
If you can figure out what make / model of furnace you have you could try online search for troubleshooting. Sorry I can't be of more help.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 07-13-2016, 06:31 AM   #8
Clicking stopped means that the electronic ignition igniter isn't working. Can you smell propane coming out of the exhaust pipe when you attempt to start the furnace? If so this means the gas valve is opening/
Can you hear the exhaust fan motor running when trying to start the furnace. If not, it sure sounds like an electric supply problem.
Suburban installation manuals usually provide a wiring diagram. If you don't have one get your model number for the furnace and download one so you can trouble shoot the electrical.
FAQs
You didn't mention where you currently are in Alaska, but they do have service centers there, if phone support can't solve your problem
ShermanD is offline   Reply With Quote
Old 07-13-2016, 07:55 AM   #9
AquaMan's Avatar
Check the sail switch.
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
AquaMan is online now   Reply With Quote
Old 07-13-2016, 07:59 AM   #10
AquaMan's Avatar
Sorry for short reply. On phone. If the sail switch becomes stuck it won't allow gas or ignition to occur.
Nights Camped
2014 - 56
2015 - 41
2016 - 81
heater, heating, suburban
