03-22-2014, 02:55 PM
Transport 20lb laying on its side?
Can I transport a 20lb propane tank on its side in my 5th wheel basement? I know I will have to secure it from rolling around, but the height with it standing up is the issue I have.
2013 Crusader 260RLD-TE
2011 Ford F250 Super Duty - 4WD - Lariet - 6.7 Diesel
03-22-2014, 03:20 PM
Just curious, why would you? Don't you already have compartments to properly store propane? But to answer your question, and this is only my opinion as I am no expert, I would say no. And the reason I come to this conclusion is that factory manufactured compartments for storing propane do not have locks because they have to be easily accessed in the case of an emergency. Your basement has locks so I would say it's a no-no. Again this is IMHO.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Rockford, Michigan
I just asked this question yesterday when having my two 30lb. tanks filled. The gentleman filling the tanks stated it was OK to lay tanks on their side. Have since done some research and based on what I have read believe it is OK to do so. You do want to protect the head of the tank from being hit by any moving objects that may fall on it. I do believe the limit you can have at one time on your RV is three 20# tanks.
Flagstaff 8528 ckss fiver
2008 Ford f350 dually 4x4 desiel
03-22-2014, 03:28 PM
Just came across this information. "Always store tanks in an upright position. That's because the top of the tank is where the pressure relief valves are located. When upright, if excessive pressure builds up, these valves will pop and bleed vapor off. While this is not good, it is not as bad as the consequences of having the tanks resting on their sides. In that position, the safety valves would bleed off raw liquid propane.
03-22-2014, 03:32 PM
Milk crate!
03-22-2014, 03:52 PM
Campfire Master
I did it once and it screwed up the over fill valve. It got stuck and I couldn't fill the tank. Had to replace the valve.
John
03-22-2014, 04:09 PM
LPG tanks need to be stored upright due to pressure relief valve.
2012 F350 Lariat CC SRW 6.7L Powerstroke
03-22-2014, 04:27 PM
03-22-2014, 04:42 PM
Propane tanks are to be transported upright and secured....
http://www.mutualpropane.ab.ca/Porta...eCylinders.pdf
Fonzie
03-22-2014, 05:04 PM
Originally Posted by Ford Idaho
Thats what I use and then still strap it down.
2012 Dodge Ram 3500 Crew Cab Dually
2015 Columbus 365 RL ( completed April 14,2014 )
Baxter and Bella [our dogs]
Days camped in 2014: 7
03-22-2014, 05:08 PM
The crate makes it .
03-22-2014, 06:21 PM
Professional Curmudgeon
Sure you can! No problem at all.
Of course, I'd recommend using a purpose built horizontal propane cylinder, such as this one:
20 lb Steel Horizontal Propane Tank
2022 Cougar Half Ton 24RDS fifth wheel
2014 Coachmen Catalina 253RKS (sold)
2017 F350 6.7L DRW CC LB 4x4 Lariat
03-25-2014, 08:49 AM
I stick mine in the front of the pickup bed in a crate that is bungee corded to the bed tie down points.
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Current Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
03-25-2014, 09:16 AM
Always Learning
The milk crate is a good idea, but the OP said he couldn't stand them up due to height issues.
