Old 03-22-2014, 02:55 PM   #1
Transport 20lb laying on its side?
Can I transport a 20lb propane tank on its side in my 5th wheel basement? I know I will have to secure it from rolling around, but the height with it standing up is the issue I have.
2013 Crusader 260RLD-TE
2011 Ford F250 Super Duty - 4WD - Lariet - 6.7 Diesel
Rickflint is offline   Reply With Quote
Old 03-22-2014, 03:20 PM   #2
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Just curious, why would you? Don't you already have compartments to properly store propane? But to answer your question, and this is only my opinion as I am no expert, I would say no. And the reason I come to this conclusion is that factory manufactured compartments for storing propane do not have locks because they have to be easily accessed in the case of an emergency. Your basement has locks so I would say it's a no-no. Again this is IMHO.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 03-22-2014, 03:20 PM   #3
I just asked this question yesterday when having my two 30lb. tanks filled. The gentleman filling the tanks stated it was OK to lay tanks on their side. Have since done some research and based on what I have read believe it is OK to do so. You do want to protect the head of the tank from being hit by any moving objects that may fall on it. I do believe the limit you can have at one time on your RV is three 20# tanks.
Flagstaff 8528 ckss fiver
2008 Ford f350 dually 4x4 desiel
racerx is offline   Reply With Quote
Old 03-22-2014, 03:28 PM   #4
Lloydg's Avatar
Just came across this information. "Always store tanks in an upright position. That's because the top of the tank is where the pressure relief valves are located. When upright, if excessive pressure builds up, these valves will pop and bleed vapor off. While this is not good, it is not as bad as the consequences of having the tanks resting on their sides. In that position, the safety valves would bleed off raw liquid propane.
Old 03-22-2014, 03:32 PM   #5
Ford Idaho's Avatar
Milk crate!
Old 03-22-2014, 03:52 PM   #6
Campfire Master
I did it once and it screwed up the over fill valve. It got stuck and I couldn't fill the tank. Had to replace the valve.
John
AVid is offline   Reply With Quote
Old 03-22-2014, 04:09 PM   #7
LPG tanks need to be stored upright due to pressure relief valve.
2012 F350 Lariat CC SRW 6.7L Powerstroke
pwrstroke2012 is offline   Reply With Quote
Old 03-22-2014, 04:27 PM   #8
In reference to my above post: I stand corrected
https://www.google.com/url?sa=t&rct=...62922401,d.b2I
Old 03-22-2014, 04:42 PM   #9
fonzie's Avatar
Propane tanks are to be transported upright and secured....
http://www.mutualpropane.ab.ca/Porta...eCylinders.pdf
Fonzie
Old 03-22-2014, 05:04 PM   #10
hihocarp's Avatar
Originally Posted by Ford Idaho View Post
Thats what I use and then still strap it down.
2012 Dodge Ram 3500 Crew Cab Dually
2015 Columbus 365 RL ( completed April 14,2014 )
Baxter and Bella [our dogs]
Days camped in 2014: 7
hihocarp is offline   Reply With Quote
sport
