Old 03-13-2014, 11:27 AM   #1
Traveling Basics - Fridge on while traveling?
Hello all
I have a question about traveling and the refrigerator.........
I need to keep it running on my Surveyor 226 TT
So dos the propane need to on when I going from point A to point B for the refrigerator to function or will it run off the electrical from my truck ?
Basic ? I guess, however this is my maiden voyage.......
Avan
Avan is offline   Reply With Quote
Old 03-13-2014, 11:30 AM   #2
Will not run off electric from truck. It should automatically go to propane when you unhook from AC power.
2012 F350 Lariat CC SRW 6.7L Powerstroke
pwrstroke2012 is offline   Reply With Quote
Old 03-13-2014, 12:22 PM   #3
The fridge runs off of the propane while travelling, it also needs 12V from the battery to operate. Not familiar with your rig but with mine once you are on shore power you can use either 110VAC or propane or let it automatically select.
_______________________________________________
Tim & Jenn
2009 Forest River Grey Wolf 235 5er
2003 F-350 Superduty 6.0 l Diesel
DSP 17K
aiscpl6 is offline   Reply With Quote
Old 03-13-2014, 05:37 PM   #4
markb5900's Avatar
To add one thing, your battery needs to be CHARGED, if you don't have enough charge, your fridge will not light. I know this some how.
If you are hooked up to your TV though, then you are fine.
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 03-31-2014, 10:31 AM   #5
masarost's Avatar
Not sure if anyone has answered your question.
Always check your RV manual. Most will tell you not to run down the road with the propane on. Your fridge is well insulated. It will hold the cold very well for several hours. What I do on my way out from home is I start up the fridge, put it on high, and let it run overnight. This way it is very cold and will keep for several hours - of course depending on outside temp.
If it is a long trip, you will probably stop for lunch, so fire it back up again then.
I have always been told not to run the propane while moving.
masarost is offline   Reply With Quote
Old 03-31-2014, 11:03 AM   #6
We always have run with the refrigerator on while traveling since 1975. Never had a problem with fueling or anything as the frig is a long way from the pump while fueling and gas vapor stays along the ground as it is heavier than air.
If you're traveling in the northeast, some tunnels require the propane be shut off while you are in the tunnels.
Old 03-31-2014, 11:21 AM   #7
wowzer's Avatar
Is the fridge suppose to stay as cold on gas as it is on electric?
Jim and Sherri Brown
2013 Silverado 2500 6.6 DuraMax
2012 Sabre 34REQS6
wowzer is offline   Reply With Quote
Old 03-31-2014, 11:22 AM   #8
B and B's Avatar
X2 here as well. Back in the 60's and 70's all we had was 1 way fridges. Propane ran all the time.
B
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 03-31-2014, 11:25 AM   #9
I have found that it stays colder on gas and adding 12 v computer fans in the back and inside the refrigerator work wonders on maintaining temps in the frig around 33-34 and 0-5 in the freezer.
Old 03-31-2014, 11:26 AM   #10
cronek28's Avatar
I was interested in how you guys would chime in on running propane while traveling.
I haven't, but thought about it on long trips especially our trip to Yellowstone with a 2 and 3 year old (lots of milk) when traveling 10 plus hours some days. We packed a cooler with ice to be safe but the frig always stayed pretty cool. On the flip side I've never heard of anyone having one blow up from a gas problem, but that would really put a damper on the trip
2013 Sabre Silhouette 320FQDS
2010 Puma 26FBSS (TT sold)
2007 2500HD Silverado Classic Crew Cab 6.5 box
"Duramax"
B&W companion slider
cronek28 is offline   Reply With Quote
travel
