Old 07-20-2014, 07:25 AM   #1
Trilogy 3850 D3 Propane Not Working
We have a 2013 Trilogy with the internal 90gl propane tank. We are at Lazy Days campground. We had the propane tank filled and it only took 6gls and the tank monitor shows full. The service propane guy let out some air to purge before filling and afterwards to see if filled. We had no problem with the propane before being filled. We tested the on/off switch both ways at the fill panel and it had no effect. The gen and water heater and stove all do not get gas. There is a co/propane monitor panel on floor in galley and it shows one green light. Are there supposed to be 2 green lights?
When testing it beeps and shows two red lights before returning to one solid green light. We are scheduled for service tomorrow and I will add it to our check list. Is the solenoid in the on/off switch bad? We never had a problem before and have only had 2 fill ups since new and they have been minimum. Maybe gremlins are loose here.
chaimemet is offline   Reply With Quote
Old 07-20-2014, 07:58 AM   #2
fonzie's Avatar
Maybe this thread will help you with your issue.....
Trilogy LP tank
Fonzie
Old 07-20-2014, 08:42 AM   #3
propane not working
read the thread before posting. My guess is the solenoid but it is more than a coincidence that after filling just a small amount the propane stopped working
propane
